12-30-2016, 12:17 PM | #1 |
New Member
Hello there. I am an author writing a story about a girl whose only inheritance is a mechanical bull. She has her Dad's '87 Chevy truck, in turquoise.
The mechanical bull weighs about 1500 pounds and is carried in an enclosed trailer. I have been trying to research if an '87 Chevy would be able to haul that heavy of a load. I know very little about cars and even less about trucks! Any advice or suggestions on my choice of truck, or suggestions for a better or different year or model, would sure be appreciated. The truck will have a big old pair of steer horns mounted to the grille. Hope this doesn't bother any purists. Thank you. |
12-30-2016, 02:55 PM | #2 | |
Re: New Member
12-30-2016, 03:11 PM | #3 |
Re: New Member
Thank you so much!
01-05-2017, 08:07 PM | #4 |
Re: New Member
Scoti, in your opinion, what would be the oldest Chevy truck that could haul this 2000+ pound load? I love the look of some of the older Chevy trucks.
One other question - is it possible an older truck from the 50's or 60's could be altered to carry a heavier load? Thank you. |
01-05-2017, 11:00 PM | #5 |
Re: New Member
Most Chevy trucks from the 30's on could handle that load. Many ranchers, farmers, & blue collar folks used these trucks as one of their work tools to provide for their families well into the 70's.
The distance driven would prob be easier traveled in a square body truck (73-87) vs the earlier models just because the revisions over the years made them more 'car' like (power steering, auto transmissions, air conditioning, etc...).
01-06-2017, 11:31 AM | #6 |
Re: New Member
Thank you so much.
01-06-2017, 12:44 PM | #7 |
Re: New Member
In my opinion a 1/2 ton short box would be totally appropriate.
Most of my family (including me and my dad) would drive a short box for the more sporty appearance and light hauling, but also for pulling trailers (cotton, racecars and other). My parents are from SE Missouri/NE Arkansas but I have family in Paducah. We may be related! K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 01-06-2017 at 12:50 PM. |
01-06-2017, 12:57 PM | #8 |
Re: New Member
Wow! Thank you so much. I'm actually from Buffalo, NY, so I'm a transplant.
01-06-2017, 10:12 AM | #9 |
Re: New Member
Since you posted in this section of the forum, most of us are going to be slightly biased towards the square body (73-87). There are plenty of older trucks that would be capable of towing that load. Since she sounds like a farm girl, maybe she should be driving a 3/4 ton truck which would have more towing capacity. The 1/2 ton would be plenty capable of towing that load, but a 3/4 ton just seems to fit better to me.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
01-07-2017, 12:39 PM | #10 |
Re: New Member
Hey Renee, thanks for time taking the time to to check this out. I'm so glad to see it matters to you. I am an avid reader and being a car/truck enthusiast, I always notice when authors add validity by getting the autos right. Not necessarily by giving a ton of detail, but by just making the details correct. Feel free to ask any questions that come to mind. We will be happy to help and the amount of knowledge possessed by the members here is staggering. Any specifics about the story that can help us tailor the truck to your character are welcome.
01-07-2017, 01:18 PM | #11 |
Re: New Member
Thank you so much!
I do have a scene where the trailer loaded with the mechanical bull starts to fishtail, swings back and forth in a vicious arc, and then plunges backward down a hill, dragging the truck with it. Maybe I could post that bit and you could see if I've got it right. (I watched some videos of trucks and trailers fishtailing and crashing.) Again, thanks so much for your help. |
01-07-2017, 06:20 PM | #12 |
Re: New Member
Well. .. In all good humor and honesty, that part might present a bit of a problem. The trucks we are into are pretty capable and the idea of being towed backward by a 1500 to 2000 lb trailer wouldn't sit well and would also be highly unlikely. The lightest of these trucks are about 3800 lbs, 5000 isn't uncommon and it goes up from there. So a trailer weighing half as much or less probably wouldn't be able to get by. About the worst scenario would be to jackknife on ice. Other than that, while dramatic, that scenario you mentioned would struggle to be believable. My half ton (light chassis) 1993 extended cab weighs 4900 lbs and is rated to tow 8500 lbs. I don't know how much my 3/4 ton (medium duty chassis) weighs, but it is rated to tow 15,000 lbs. As you can see, having the little trailer pass the truck is almost something one would have to Try to do. And even then, probably wouldn't happen. I don't know how you want your character's driving skills to be seen, but they would have to be severely lacking for that to take place under any conditions. That said, an ice storm can cause lots of things to happen, and I don't know what you've found in videos. You might be sorry you asked now, haha, but I for one would be frustrated to read that a character in a half ton truck was pulled around backwards by a little trailer, unless she had driven into a tornado :-)
LT7A |
01-07-2017, 06:54 PM | #13 |
Re: New Member
OK, that makes sense. When you're writing a story, you sometimes have to tweak things, so what if she had an older vintage truck, something like the photo here. And then what if the trailer and bull were heavier? A lot heavier?
01-07-2017, 06:55 PM | #14 |
Re: New Member
01-07-2017, 06:57 PM | #15 |
Re: New Member
I'm trying to paste the photo of a vintage Chevrolet Apache pick up but it's not working. I realize I'm in the wrong forum for this, too. but thanks for the advice.
01-07-2017, 06:58 PM | #16 |
Re: New Member
01-07-2017, 06:59 PM | #17 |
Re: New Member
P.S. If you can add enough to the trailer that it outweighs the truck by 2x and there is inclement weather, you are getting closer to believable.
01-07-2017, 07:14 PM | #18 |
Re: New Member
If the mechanical bull weighed more then she would/could have problems loading and unloading it. A come-a-long would load it, unloading not so much.
01-07-2017, 07:21 PM | #19 |
Re: New Member
The bull comes apart in two pieces, and it takes two people to load it. Then there are inflatable bumpers and ring, a controller box, 2 heavy cables, a dolly, and other assorted stuff that goes with it.
01-07-2017, 07:33 PM | #20 |
Re: New Member
Clearly you like to have detailed knowledge. Well done. Having a tire blow out would help a lot. Especially if she's going pretty fast. Should be one of the truck tires, not the trailer. Speed + weight + rain + blowout could turn into a wild ride for anybody.
01-07-2017, 07:58 PM | #21 |
Re: New Member
OK, then I think I have my scene! Thanks to all of you for your help. It's much appreciated.
01-07-2017, 07:10 PM | #22 |
Re: New Member
That's funny, I got a phone call as I finished my last post. So I took the call and then submitted the post. In the meantime you have gotten to right about the same idea. Those Apaches are beautiful trucks and are going to be quite capable. There are factors you can add if if the truck is somewhat worn out, the steering components are worn, the tires are worn, etc. And the heavier the trailer is, the more possible it is for it to push the truck around. I think you'll at least need wet weather and some winds if that's possible. Maybe she has a big old horse trailer, and she loads the bull up a ramp into the back? Maybe the rest of the trailer is full of other earthly belongings? if the trailer is loaded unevenly (weight to the back, not over the axle) it will be less stable. I'm not trying to jump in and write part of your book, haha. Just throwing around ideas.
01-07-2017, 07:13 PM | #23 |
Re: New Member
Those are all great ideas and I'm sure I could make it rain! What if a tire blew out?
01-09-2017, 08:44 PM | #24 |
Re: New Member
Thank you, that would work, too, and help make the scenario more believable.
Tags |
'87 chevy, mechanical bull, turquoise |
