02-13-2017, 05:19 PM | #1 |
1970 K2500 needs new rear axle
Hi. My 1970 GMC 3/4 ton 4WD pickup has a 4.10 Dana 60 rear axle that has significant damage to one of the spindles, so I need to replace it.
I know the 2WD rear axles are different, but what exactly is the difference between the 2WD and 4WD rear axles on this truck? I'm also thinking about maybe upgrading the rear axle to a later model 14 bolt. Exactly what years and model trucks should I be looking for to do this? I'm a welder so I don't mind fabricating spring perches, etc. if I have to, but does anything just bolt in? I don't really care one way or the other about disk brakes. What is REALLY important to me are good parking brakes. Is there any difference in holding power of the disk brake rear end parking brakes vs. the ones on drum brakes? Thanks for any help! |
02-13-2017, 06:03 PM | #2 |
20' Daredevil (Ret)
Re: 1970 K2500 needs new rear axle
Welcome! I am still running an Eaton HO52 in my '72 K20. Unless you have a good one lying around, you probably won't want to swap to one of those. About the only input I have is..... I am pretty sure drum brakes will hold (as a parking brake) better than discs. Many disc brakes use a small drum as a parking brake. Full-size drums should hold better. IMO, that's the only advantage drums have over discs.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
02-13-2017, 06:53 PM | #3 |
All about them K’s
73+ 1 ton 14 bolt srw is a bolt in minus moving a shock mount. All other 14 bolts will need perches moved and shock mounts as well.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
02-14-2017, 01:52 PM | #4 |
02-14-2017, 04:04 PM | #5 | ||
"I ain't nobody, dork."
I would say to the early 1990's. You want the beefier 8-lug full floating or even a semi-floating rear axle with the 14" ring gear. Bomb-proof.
The even later model version of the 14 bolt is a lighter duty 9.5" ring gear axle that was under 1/2 tons is only a 6-lug and significantly weaker than the 8-lug version. Gary
02-14-2017, 06:52 PM | #6 | |
I've learned there is a major difference in drum brakes of 14-bolt rear axles. Some of them slide off the studs which is the same on my Dana 60, and some require the axles and hubs to be removed? I am only interested in the kind that allows the drum to slide off the studs (I don't want to deal with removing the axle and hubs just to check the brakes). What year 1-ton trucks have the style of rear brake drums that just slide off the studs? Thanks! |
02-13-2017, 09:26 PM | #7 |
Yes. A disc brake rear end has one of two setups:
- A mechanism for grabbing the disc via the caliper, ala Cadillac, but they don't hold well - A drum inside the rotor hat I prefer the little drum inside the hat, but it's a lot less surface area being grabbed than by drum brakes. Unless you're going to road-course the thing or tow in the mountains, I can't think of any reason I'd mess up a good system to do rear discs. I've generally regretted it when I've done it, and now run drum/disc in most vehicles. My C2500 has the D60 as well, I'm also curious as to what the difference is 2WD to 4WD.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
02-13-2017, 09:52 PM | #8 | |
All about them K’s
02-13-2017, 11:02 PM | #9 |
Born Psycho
let me check with a buddy of mine to make sure he still wants the one i have. if he doesn't want it, i'll make you a hell of a deal on it. i'm only a couple hours from you so you can come pick it up. it came out of a 71 GMC 2500 4x4. P.M. our phone number and i'll let you know if he doesn't want it.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
02-14-2017, 01:56 PM | #10 | |
02-14-2017, 10:50 AM | #11 |
There ya go. Moss Man to the rescue! I hope it works out.
02-15-2017, 01:08 PM | #12 | ||
That would be the semi-floater without hubs out back. It uses regular drums like any other non floating rear end. I had one under a 1991 3/4 ton Suburban.
Gary
02-15-2017, 02:21 PM | #13 |
How bad is the spindle? They make speedi sleeves for that. Otherwise it could probably be welded and ground back down.
