![]() Join Date: Mar 2011
DIY Powder Coating
long 6 year story ....bought the PC kit from Eastwood 6 years ago used it for the first time last night
![]() thanks Jess
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
![]() Join Date: Oct 2009
Re: DIY Powder Coating
No real point to pc threads - I'd just keep em oiled every once in awhile. PC is nice - and that looks great. I'm always torn - it's easy to scratch, so be careful!
#3 | |
i can and will tape up threads and put grease on them after I coat them, just wondering if anyone has put them in oven sweated the grease out clean them up and prep at any rate painting or powder coating them you have to remove the grease that the manufacturers installed just looking to see if anyone experienced powder coating these ?
Yes, you have to break the tie rod ends down and tape the threads. As you probably figured out, coating on threads will cause them to not fit the nut and all it will do is pop off as you tighten. I've never done my own but have been having a place do mine since the '80s, so I've gotten an education. I'm friends with the owner and he has educated me on a lot of it, from all the various pieces I have had done. People say not true, but he told me they only do individual pieces. The tie rod end has moving parts. Maybe it can be done, but when the parts move the coating will have to break and won't that start the deterioration process? Powder coat is a shell and once compromised will hold in water and the coating can become unbonded and come loose as a shell. I would tape up the ball socket and stud so the only thing coated is what is exposed. That's all that matters.
#5 | |
and should just paint it all and hone my skills on straight forward parts ![]()
I plan on taking my large dead freezer that is 6' tall and 3' wide and pulling the plastic inner and lining it with steel and making it an oven..
any suggestions on how to hang coil springs for coating then baking
It's a a good idea to clean and heat to make sure no grease/ oil is left behind and I wipe down again after cools down.
1972 Custom Deluxe 20 4x4 burb 1971 GMC SWB CST 4x4 1972 GMC k20 4x4 (X- brush truck ) 1971 Chevy CST Blazer 4x4 1971 Chevy C/10 1970 Cab Chassis C30 157" 1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica ) 1988 Chevy V30 4x4 wrecker challenger 4812 |
![]() Join Date: Jun 2009
Something here just does not sound like a good idea to me. I think I would stick to the standard paint, I used semi gloss black wheel paint on mine as it bonds great and holds up well. Stick to the easier parts Jess
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
I know you are right Larry I'm going to paint the steering parts . what you think about me tac welding a wire hoop to each end of the spring to hang it PC and then grind off hit those spots with a touch of POR15?
Just hang it with a heavy gauge wire. I like to use drop ceiling suspension wires.
Brad handshoe |
built my own oven today for the longer c-members ....only need 400 degrees for 20 mins LOL ...will see how she works tomorrow
More pics of this incredible idea...........
http://i204.photobucket.com/albums/b...baae5d9a7e.jpg |
You my friend are a genius
#15 |
Get a roll of tie wire http://m.homedepot.com/p/Weyerhaeuse...5337/202094311
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
#16 |
I'm pleased my oven works well on the right is the rear most C-member i used a Satin ...is a little to flat for me so i added some semi -gloss to the satin and coated the clamshell ( middle ) and got the desired results. The SB engine stand is semi gloss and the bracket that holds the A-arm cross shaft was done professionally
#17 |
Very nice Jess, you seem to be closing in on me
#18 |
your moving at light speed ....and inspiring, its going to be fun to follow, best I could do now is bring up the rear
