04-13-2017, 12:59 PM | #1 |
What is involved in changing a 46 Chevy Grill to a GMC
Can someone tell me for sure what I need to change other than the grill to put a GMC grill in my 46 Chevy? I have a GMC hood and hood sides. I also have the lower splash pan behind the grill but not sure if I need it since I am not running the original frame under the truck. I also know the filler panels in the corner of the grill, hood and fender are different. What about the upper filler panel? What about the front trim that holds the front of the hood? Thanks.
Here is my build thread http://67-72chevytrucks.com/vboard/s...d.php?t=383658
Note: All parts I have for sale are also for sale locally. I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts. |
04-15-2017, 03:12 AM | #2 |
Re: What is involved in changing a 46 Chevy Grill to a GMC
todd some of the guys here are also active on stovebolt.com, I dont normally advocate another forum but those guys are accurate to a hundred thousandth (sometimes exasperatingly and slightly disturbingly, but from a place of best intentions not malice) and I would bet you would get part numbers and an assembly manual page or two and maybe the correct angle to hold your tongue when installing from this question.
04-17-2017, 07:52 AM | #3 | |
Thanks for the advise and help. I will get back on there sometime and see what I can find. Thanks again.
04-17-2017, 03:36 PM | #4 |
I am sorry to hear that. you are right that the feeling there is "being technically correct is the best kind of correct" but as long as you have some fairly thick skin for being corrected I have found it a useful resource, at least the positives for me outweigh the fiddly negatives.
I have seen in person three different front fender types. 1/2 3/4, the 1 - 1.5 and up, the ones you describe that my friend called a GMC 1 1/4 ton. I have even seen them for sale on the stovebolt classifieds so I am surprised they argued that point.
08-07-2017, 11:05 PM | #5 |
I believe you need a gmc core support to run a gmc grill. I tried to replace my gmc core support with a chevy one and it is different
08-17-2017, 08:58 AM | #6 |
Thanks, I think I have almost found everything. I just need the filler panels between the fender, hood, hood side and grill. Might be able to modify my Chevy ones but hoping to find the correct ones. Thanks again for you time and information.
