04-17-2017, 01:33 PM | #1 |
Daily driver 327 ideas?
Well have been driving my 1966 C-10 for 10 years or so now. Looks like its time for a rebuild.
Looking at about $500 - $800 to rebuild the 327. Whats the most performance I could get out of the engine in that price range and have a fun daily driver. Currently it has a Edelbrock streetmaster manifold and Edelbrock performer 600 cfm electric choke carb. Other then that its stock.
Are you a collector? If so come check out Collectorsunleashed.com Doesnt matter what it is we have a spot to show it off. http://www.collectorsunleashed.com/# |
04-17-2017, 04:45 PM | #2 |
Re: Daily driver 327 ideas?
I think you'll be hard pressed to do a stock rebuild for that if you do all the work, including the machine work.
And it's a matter of opinion, but I could have a "fun daily driver" that's a 6 cylinder 3-speed.
Alex V. ------ 1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs. 1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue. |
04-17-2017, 05:44 PM | #3 | ||
"I ain't nobody, dork."
You'll spend that much in machine work for a rebuild. $500ish without the heads being rebuilt. You will probably need to budget about $1,200ish for a rebuild with head rebuild included. That's for all stock internals. You can get a cam ground locally for a bit cheaper if you just let them know what cam profile you would like them to follow.
Gary
04-17-2017, 11:51 PM | #4 |
60-66 Nut
I agree that you are not going to rebuild a 327 in that price range. You might be able to do an overhaul, but that will likely be short lived.
04-18-2017, 09:17 AM | #5 |
Hmmmmmmm. Looks like I will be saving some more cash then. well will have to see here in a few weeks what shape it's in once I pull it out.
Thanks Posted via Mobile Device |
04-27-2017, 10:30 AM | #6 | |
What they said above +1 , but No Buddy - really mentions BALANCING ! Most Important Player in the Game of Building .. |
04-27-2017, 01:05 PM | #7 |
I'd save about $2000. That way you have plenty to work with. Believe me you won't regret it. Bout the cheapest you could do a bone stock rebuild would be $1200 around here. And with $800 more on hand you'd have some play room....like zero decking the block for more compression....shaving the heads....or getting a new cam with some more lift....and yes...Balancing everywhere. I'd also look into headers and an hei. 327's are great engines. Run high quality oil and it'll last you a long time if you can keep your foot out of it. lol
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
04-27-2017, 08:56 PM | #8 |
I kicked this around too, and the best advice I got here was to buy a crate 350 if you are looking for "bang for the buck".
The rebuild thing is a "labor of love" but the economics don't pan out. If you really love your motor and want to keep the 3100 with the original motor, it makes sense. The fact that you can get a brand new GM Motor for $1500 is just unbelievable, considering you'll have double that in a do it yourself job. http://www.jegs.com/i/GM-Performance...FUtqfgodH14IIw I thought about the crate motor with a 4x4 cam, and new vortec iron heads and intake. That would add about 1200, but "how sweet it is" and you could sell your 327 to spread that cost out a bit. Good luck! |
04-29-2017, 10:47 AM | #9 |
I just did a 327 shortblock bored/balanced they also freshened the heads up $1400.I could of saved a coupla $$ installing pistons and crank myself but hell they can do it while its there. The problem lies in finding a good machine shop that doesn't gouge you for there ego.
Don't really know until you tear it down you may just re-ring/bearing it and freshen heads up. Very good motors to run
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 Last edited by kaycee; 04-30-2017 at 10:51 AM. |
04-25-2017, 05:49 PM | #10 |
But Found Her 25yrs Later!
I figured when my 283 gets tired, I'll just get a crate. I know... I'll just be another guy with a 350.
04-26-2017, 12:05 PM | #11 | ||
Badge the 350 as a 283 and run a sneaky PCV system and use an intake manifold with a front oil fill tube. No one will ever know but you!
Gary
04-26-2017, 01:19 PM | #12 |
driving is in my blood
$500 is a refresh unless you own a machine shop yourself. $800 is getting closer, I'd say more like $1200 for a stock rebuild. Its the reason goodwrench 350's are so popular. But not having a 350 is cool, so rebuild.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
Tags |
327, chevy 327, sbc |
