Old 10-06-2017, 09:24 AM   #1
Marine-58
Marine-58's Avatar
Transmission Swap Advice
Starting to gather parts to swap out the TH400 for a 1994 4L60E. Wanted to add OD before swapping the rear gears to 4.10. Ran across way too good deal on a good tranny that won't need a rebuild. What I'm needing help with is to make sure I have everything before starting the swap. Been researching on the internet and there appears to be a lot of articles on this but each one speaks to a part of what is needed. You guys are much smarter at all this, so hoping for some validation.
To set up the end goal:
72 C10 SWB
383/465hp
12 bolt 3.55 soon to be 4.10
20X8.5wheels
275/60R20 tires
Swapping to 15X14 wheels
29X18.00R15 tires
Rear end - 12 bolt 65" WMS to WMS
Narrowing this to 56 - 58" Pending measurements
Bed is already Tubed
Shifter is a B&M Mega - can be changed to allow for 4 speed by removing a pin.
Here is what I have found out so far:
Torque Converter - going with a 2500 RPM Stall Speed. Not sure of brand yet. $300
Cross Member - needs to be moved but not sure if needing a different one - $10 (Junk Yard)
Driveshaft Yoke - Will find in junk yard - $10
Electrical Speedo or a electric to mechanical conversion $250
Control box - numerous ones to choose from - like the TCI set up, but not sure. $700
Throttle Position Sensor and bracket - ??
Time/Money/Patience... $priceless
All in about $1,300 + TPS and bracket.
This is about all I can derive so far. Will certainly appreciate any and all advice...
Thanks,
David
72 Chevy C10 383/465
69 Corvette convertible 454/650
Marine-58 is offline   Reply With Quote
Old 10-06-2017, 11:08 AM   #2
Bigdav160
Bigdav160's Avatar
Re: Transmission Swap Advice
I wouldn't consider an electrically shifted transmission if I wasn't going fuel injection.
But that is me
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 10-06-2017, 11:12 AM   #3
Marine-58
Marine-58's Avatar
Out of curiosity, why wouldn't you? The controller allows for on-the fly adjustments for shift points and firmness. Driving to work, can make it shift "normal" for hot rodding around, set it for a later and firmer shift point.
The downside that I can see is the cost of the controller. But even at $700 + the $100 I paid for the tranny, I'm still ahead of building a 700R4.
But then I am asking for advice, certainly may be overlooking something....
