![]() Join Date: Sep 2005
Radiators
So my 4 year old griffin radaitor has spun really bad leaks from both side where the cores go into the tanks griffins warranty is only 2 years took it to a radaiotr shop and they said it cant be fixed i really dont wanna spend another 300 on another griffin to find out 4 years later it doing th same thing and they wont stand behind them but i also dontt wanna spend 900 buxs one a new one either anyone got any recommendation on what they are doing its a 1971 c-10 with 4.8 ls i dont drive the truck but maybe 500 miles a year
Re: Radiators
Im using a factory one. 32k miles since the swap and works great.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
Re: Radiators
I don't have any experience with them, but Cold Case radiators have a lifetime warranty. Not too expensive either. FYI... I ordered one for a LS swap a few days ago at the Goodguys show in Charlotte. These haven't hit the market yet but he said I should have it by the first of the year. I got the LS style radiator, shroud, and dual electric fans for $500 w/ free shipping. I didn't have to pay for it yet either so If I change my mind before it arrives, I'm not on the hook for it.
Re: Radiators
Thanks steve i will look them up, nova i no long have the orginal rad as it too was leaking from the middle of the cores they said ti was fixable being all cooper but wanted 290 buxs to recore it so i just bought an all aluimn one figuring id get lots of use out of it i was wrong
![]() Join Date: Jan 2009
Re: Radiators
Try a Champion I think there are on eBay Fair priced aluminum
Pulatoy |
Re: Radiators
Re: Radiators
this is the reply fron cold case
David, We don't offer a LS swap version for a chevy truck. What that person probably got was our A-Body LS Swap radiator which is similar and could work in its place. Check it out online here: http://coldcaseradiators.com/buick/6...inum-radiator/ COLD-CASE Radiators 2705 Clemens Rd B103 Hatfield, PA 19440 www.coldcaseradiators.com
Re: Radiators
which the specs for the abody ls swap from cold case are almost the same size as the griffin radaitor
Re: Radiators
He told me the 67-72 chevy LS truck radiators were in there cue to be produced. He said they would be a direct fit, direct replacement. I will call about this to confirm.
Re: Radiators
stock 4 core here too.
never understood why everyone gets all worked up and wringing their hands together over this issue. it fits. it cools more than adequately. looks like it belongs. <shrug> |
#11 | |
Re: Radiators
If that is not big enough for you get one for a 454 HD
Re: Radiators
My problem was the stock radiator was shot so i bought the all aluminum radiator and now the stock replacment rads are aluminum with plastic tanks so that sounds crappy to me
Re: Radiators
Ive got a stock replacement cold case and so far it looks nice. I pulled it out of the box and looked at it but that was about it. The thing that sold me on it were the stamped aluminum tanks, I just think they look better than fabricated tanks.
Re: Radiators
I am thinking of trying a big champion for the price you can't beat them. I would like to see a detailed photo of the install.
. My Griffin was not a great fit from new and is at least 6 years old just starting to crack bad in the epoxy .It's days away from leaking bad I can smell it.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
#15 |
BMW & ASE Master Certified
Re: Radiators
Stock AutoZone square body 454 row aluminum core type radiator for the last 8 years of daily driving status.. 5.3 4l6e, ac, mechanical fan... recommend electric fans
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
#16 |
Re: Radiators
Yes that is what I was just say'n!!
#17 |
Re: Radiators
https://www.ebay.com/itm/1968-1977-C...1ZzUGz&vxp=mtr
may try this one for a chevelle teh diamentions are almost exactly the same as the truck rad
#18 | |
Re: Radiators
You don't need the tranny cooler? |
#19 |
Re: Radiators
it would be nice but mines always been hooked up as an exterinor cooler since the girffin didnt have one either
#20 |
Re: Radiators
Is your external tranny cooler in front of the radiator? Does it have a dedicated cooling fan?
#21 | |
Re: Radiators
Thanks. |
#22 |
Re: Radiators
Its hanging off the front of the core support infront of the radaitor and i have a fan sitting on my toolbox at work but havent yet put it on plus it had the other radiator fan mounted right behind it on the rad havent had a problem yet but was thinking itd be nice to have one woth internal cooler
#23 |
Re: Radiators
I havent done anything yet i had to put like 2300 dollars into the front end of my suburban and tires on it
#24 |
Old member
Griffin radiators suck. They are just down the road from me and I want buy them. They are not customer friendly at all.
I went to them when I did the 6.0 LS swap and they basicly told me no they wouldn't build me a radiator. 4 years and it's not showing any sign of leaking. Full welded no expoxy! ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=681849
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#25 |
Re: Radiators
If you haven't already picked up a new radiator heres my feedback. I have a Champion CC369 which is a 3 row for my 5.3 from Jegs.com. I only have about 750 miles on my Ls but the radiator is really nice. fully welded tanks, trans cooler connections, and even a heater hose input which I used for my steam vent lines. It inst hot here in Cali at the moment but my truck is cooling just fine. for the price they are hard to beat. full disclosure I used to sell Champion radiators and got decent feedback but didnt have personal experience with one installed in my truck until recently because my existing rad was fine. So far so good since install.
Lifted 2wd 1969 C20/ 5.3LS/4L60E :http://67-72chevytrucks.com/vboard/s...d.php?t=728388 |
