Old 12-18-2017, 04:43 PM   #1
1SG.Rob
1SG.Rob's Avatar
Wiper fuse keep blowing
This weekend I replaced the in-dash main wiring harness. It cam with a brand new fuse box and all the wires to OEM specs. We got it installed but every time we turn on the ignition, the fuse for the wiper motor blows. Even when the plug going to the wiper switch is not attached. Any ideas? I am a novice at best when it comes to electrical systems. My worry is that the new fuse box is bad and I will have to replace it. Thanks!
1SG.Rob is offline   Reply With Quote
Old 12-18-2017, 04:50 PM   #2
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: Wiper fuse keep blowing
Unplug the wiper motor itself. The switch provides the ground circuit for the wiper motor if I am correct.
http://67-72chevytrucks.com/vboard/s...d.php?t=584603
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 12-18-2017, 05:12 PM   #3
1SG.Rob
1SG.Rob's Avatar
Why would replacing the wiring harness change anything or cause the short? The wipers worked just fine before I replaced the wiring harness. I didn't replace anything going to the wiper motor, just the wires to the switch.
Old 12-18-2017, 05:20 PM   #4
harpo231
harpo231's Avatar
Sounds like something new is bad
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 12-18-2017, 05:20 PM   #5
71meangreenc10
Maybe that harness has a hot circuit instead of a ground going to the switch. Time to get a test light or a multimeter out.
If it is an aftermarket harness, it may be wired to what most people think of as hot when a switch is used. That is not how this circuit was designed. Unplug the wiper switch and the motor and probe the circuit to see how the new harness is sending 12v. Sounds like a hot is going into the ground side at the motor. Check the link I sent you to see the differences.
Smitty
71 C30 Wrecker
Old 12-18-2017, 07:09 PM   #6
1SG.Rob
1SG.Rob's Avatar
Thanks for the advice and help. After reading that and then remembering to account for the fact that I'm a dummy, I saw that I had plugs going to the wiper motor in backwards. Switched them around and now the wipers work like new. Thanks again, Smitty.
Old 12-18-2017, 07:14 PM   #7
71meangreenc10
No problem,
We all have those moments....
Smitty
71 C30 Wrecker
