Old 12-27-2017, 03:10 PM   #1
Bdb68
1968 Custom Camper Duramax
Quick history;
A friend of mine bought this truck off of craigslist for parts. We drove 5 hours from Kentucky to northern Ohio. It was dark when we got there, checked everything over with flash lights and loaded it up for the 5 hour drive back. The next day in the light after looking the truck over I decided I liked the patina too much to cut it apart. I bought the truck from buddy and decided I wanted a quick and cheap build using what I had laying around. The truck started out as a C-20 two wheel drive Custom Camper. The truck was in pretty good condition, the motor and trans were gone, but someone had taken care when removing them. everything was unplugged and tied up, not cut. The truck had the usual rust in the rockers, cab corners and radiator support.
1955 Chevy 210, 6.0ls supercharged
1968 C10 original paint, 2wd, swb, 6.0ls/ 4l80e
1968 Custom Camper 4x4 Duramax Build Site.
1972 Crew Cab Project
Bdb68 is offline   Reply With Quote
Old 12-27-2017, 03:23 PM   #2
Bdb68
Re: 1968 Custom Camper Duramax
Pictures
Old 12-27-2017, 03:42 PM   #3
Bdb68
Phase 1 Quick and Cheap.
Several years ago I bought a Suburban body on a rolling frame to build a crew cab. The frame had been converted to 4x4 and was powder coated. The plans for the crew cab are to set the body on a late model truck frame. So I stole the powdercoated 4x4 frame from the Surburban for this truck. To make it fit under the pick-up we had to move the some of the cab mounts around and drill holes for the bed to mount. We also cut a few inches off of the back of the frame so the bed would fit. The wheel base was off around 2 inches but we fixed this with later model longer springs and moved some things around. We installed a 305, 350 turbo and 205 transfer case. I picked up some 3/4 ton rearends from a buddy and we had the truck running and driving in around 3 weeks.
Old 12-27-2017, 03:59 PM   #4
Bdb68
Picture 1, the 14 bolt converted to disc using parts for the same year model front end and a set of brackets made by a friend of mine. The springs I had were junk so I bough a 4 inch Rough Country spring lift.
Picture 2, the 305 I had laying around, has about as much power as a golf cart
Picture 3, Interior Untouched
Picture 4, shows how good of shape the floor was in and my homemade shifter comming through the floor.
Old 12-27-2017, 04:13 PM   #5
Bdb68
Phase 2, The fun begins.
After about a week with the 305 we decided it needed more power. I drove it into the garage. We removed the 305 and had planed to install a 6.0L LS with an adapter flywheel to use the 350/205 trans and transfer case already in the truck. Sometime overnight the plan changed from doing a quick and cheap ls swap to a diesel convesion. A few weeks prior, I picked up a Duramax LB7, Allison and transfer case on Craigslist. It came with the wiring, computers, radiator, inercooler and other parts. This was going to be the powerplant for the crew cab. However I decided it was taking up entirely too much space and would be a while before the crew cab was ready for an engine.
Old 12-29-2017, 05:18 PM   #6
winslowgoodwin
nice
winslowgoodwin is offline   Reply With Quote
Old 12-31-2017, 10:41 AM   #7
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
It's looking sweet. Are you using Ken for the stand alone wiring? 4 or 6" lift?
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 01-07-2018, 08:02 PM   #8
Bdb68
Thanks everyone.
Yes Im planning on using Ken from stand alone harness. I am planning on mailing it in tomorrow. 4 inch Rough Country liftkit. Progress has been a little slow lately because I have been traveling a lot for work lately.
Old 03-01-2024, 12:05 PM   #9
Dan Castilleja
Thumbs down Re: 1968 Custom Camper Duramax
What motor mounts did you use?
Dan Castilleja is offline   Reply With Quote
Old 01-03-2018, 06:20 PM   #10
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Welcome to the 67-72 board, and very nice truck! That all worked out well. A 4 door build is on my list of to do's some day as well.
Ryan
1969 Chevy milk truck
Old 01-15-2018, 05:00 PM   #11
Bdb68
Updates:
Homemade lift pump and dual filters (same as cat filters)
4 inch mandrel bent exhaust with flow through muffler
The huge Allison transmission fits under a stock high hump
Drivers side battery box
Passengers sides inner fender modification to fit stock air filter box
Old 01-15-2018, 09:50 PM   #12
Dieselwrencher
Nice work. Is that lift pump a knock off holley blue?
Ryan
Old 01-16-2018, 10:41 PM   #13
Bdb68
Dieselwrencher, I can't remember if its a knock off or the real deal that has lost its stickers. I am going to give it a try because I had it laying around. I made the mounting plate for the filters extra wide, so if the Holley doesn't work I'm going to go with a purpose built lift pump like in the picture below. The picture below is where I got the idea, I found the picture on Google, not sure who it belongs to. Also, I really like your truck and build thread. I have done several LS swaps but this is my first Diesel swap. If you have any ideas or advice, or if you see me doing something that could cause problems please comment or send me a message. Thanks
Old 01-16-2018, 01:10 AM   #14
hick
OOOOOOOOOOOOOOO
2018 just got really good for reading material...
1989 3+3 2wd Dually. 454 BB. Factory loaded for the day, including Alcoa rims.
hick is offline   Reply With Quote
Old 01-16-2018, 10:56 PM   #15
Dieselwrencher
Thanks, and no problem, will do. I got burnt on a knock off holley blue is why I asked. I happen to have an airdog for a duramax setting in my shop. I don't know if it even works. I can't remember where it came from.
Ryan
Old 01-17-2018, 09:56 AM   #16
Bdb68
Dieselwrencher, If my home made set up doesn't work out I might be interested in it.
Old 01-17-2018, 10:21 AM   #17
Bdb68
Picture 1 and 2 show the new front cross member. The old one probably would have worked, however it was bent pretty bad and it got in the way of the stock Duramax radiator hoses. The new cross member also ties in the front spring hangers and incorporates a standard size receiver through the bumper for a portable winch or removable tow hook. I may make a license plate holder that slides into the receiver to cover up the hole. The last picture is of the added gussets in the engine area for the added weight of the engine.
Old 01-17-2018, 04:40 PM   #18
Dieselwrencher
That will work out great for a portable winch! Great fab and welding too!
Ryan
Old 01-23-2018, 02:44 PM   #19
1972K20
1972K20's Avatar
Good looking build
1972K20 is offline   Reply With Quote
Old 01-31-2018, 09:08 PM   #20
rgreathouse
awesome build I'll be following this one!
1972 c10,2wd,long bed,250,4spd---->
1972 SWB Fleetside 4x4 12v Cummins build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=513791
rgreathouse is offline   Reply With Quote
Old 02-05-2018, 01:25 PM   #21
Bdb68
Thanks guys, I cant take credit for all the welding. All of the heavy welding was done by my buddy Mike.
I have just about figured out the brakes and steering. I started with a hydro boost unit from a 2005 gas 2500 Chevy, I assume they are the same as a Duramax truck. I cut the studs off of the mounting bracket and drilled holes to match the studs coming out of the 68's fire wall. I removed the clocking tabs on the bracket so I could spin the bracket upside down to better align with the 68's studs. I had to enlarge the hole in the firewall so the large nut from the hydro boost would fit. I used the stock 05 lines from the power steering pump to the hydro boost. The 05 line from the hydro boost to the steering box had to be modified. The late model lines are O-ring and my steering box is flare. So I simply cut off the o-ring, and flared the end. I had to do a little modification to use the nut off the 05, but I would recommend finding the old style nut made for a flared line. I then used my old return line from the steering box to pump and the 05 hose from the hydro boost to the pump. If anyone wants a better explanation or more pictures of this just ask.
Old 02-05-2018, 01:31 PM   #22
Bdb68
For the time being I decided not to mess with a heater. So to bypass my heater core I used this hose from Autozone. I have used the same hose to bypass a heater on LS swaps. One side is 5/8 the other 3/4. Simply trim the long side till its the right shape and hose clamp it on.
Old 02-05-2018, 01:56 PM   #23
Bdb68
Exciting update: I received my computer and wiring harness back and got the engine to fire up over the weekend.
Harness was doe by Ken at standaloneharness.com
Computer was tuned by Nate at Stulldiesel here in KY
Once I got it primed and found enough battery power, I had to jump it off my 16' Duramax, it fired right up. No smoke, and surprisingly quiet coming straight out of the down pipe. One note, my lower inner cooler boots had not yet arrived so it had no boost. see the link below for a start up video
https://youtu.be/s2cPyPCa_TY
Old 02-06-2018, 12:22 AM   #24
Dieselwrencher
Awesome! Is that a 55 setting next to it?
Ryan
Old 02-06-2018, 09:30 AM   #25
Bdb68
Yes it is. This is my 55 Chevy rat rod. 2005 6.0L with a magnacharger, 4l80e, and a Ford 8.8 narrowed rear end. If I ever get around to making a build thread for it, I will post the link on here.
duramax conversion, duramax swap
