01-13-2018, 02:34 PM | #1 |
Identify this: Accelerator controls off of ???
Tearing down my mutt of a 1969 K10 to deal with a flimsy accelerator pedal*. It's definitely not stock, nor in great shape. Anyone know what this is off of? Cross checking LMC catalog it doesn't appear to be off of a Chevy pickup between 1967-1989, but the drawings could be misinterpreted. It is accelerator cable, not rod.
*Pedal was attached to rod by a bent roofing nail, Rod support mount cover plate is plastic and very cracked/cut. |
01-13-2018, 02:37 PM | #2 |
Re: Identify this: Accelerator controls off of ???
And the images...
01-13-2018, 03:51 PM | #3 |
Looks like someone attempted to install the later (71-72) cable style pedal in a early "rod" style truck.......
1967 C10 SWB Owner - Rustbelt Restorations |
01-13-2018, 04:28 PM | #4 |
71 Chevy/GMC
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
01-13-2018, 04:52 PM | #5 |
Thanks all! Does anyone have a pic of one installed? The diagram in LMC truck looks different to me.
01-14-2018, 06:22 PM | #6 |
So, the mount bracket attachment points are all spaced 2" on center (equilateral triangle).
01-14-2018, 09:21 PM | #7 |
01-14-2018, 09:21 PM | #8 |
Sorry for the huge pic
01-14-2018, 10:25 PM | #9 |
Thank you for it! Are there any return springs hidden in there or just up at the carburetor?
It's looking like I have the pedal, shaft, and cable off of a 71-72, but it's mounted using the traditional 67-70 bracket. |
01-14-2018, 10:52 PM | #10 |
laying low
Here.
01-15-2018, 12:21 AM | #11 |
Looks like my '67 pedal before the rod broke in half inside the "mounting plate". I replaced it with a Lokar pedal & cable setup.
1967 Longbed 4/6 static 2007 Silverado Z71 Crew |
01-27-2018, 06:23 PM | #12 |
Going to attempt the quick fix: http://67-72chevytrucks.com/vboard/s...00#post1383300
01-27-2018, 08:13 PM | #13 |
What year did they change the hindge floor mounting, to firewall only? Are there any bolt holes in the floor under pedal?
01-27-2018, 08:15 PM | #14 |
The 69 was a hinged floor originally. Alas, the floor pan had long since disappeared--along with it the pivot points.
01-28-2018, 10:44 AM | #15 |
They went to a cable throttle in 1971. The earlier trucks did have a nutplate under the floor that the ball studs screwed into that the pedal snapped onto. 71-2's still have the flat spot in the floor for them, but no holes or nutplate of course.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
Tags |
1969 k10, accelerator, accelerator cable, accelerator pedal, k10 |
