01-23-2018, 02:50 PM | #1 |
Location: 3,018 feet above the SoCal/Mojave Desert region.
Help with adding oem style tach.
1969 GMC will be installing a new Tachometer Instrument Panel Gauge Cluster Set. My original doesn't have a tachometer but I would like one installed with one. Where do i connect to??
01-23-2018, 03:03 PM | #2 |
Re: Help with adding oem style tach.
If you send me a pm with your e-mail I can send you a set of (pdf) instructions that I developed which outline how to remove the existing dash assembly and re-install with the Tach.
Its detailed and includes needed tools, time, methods and specifics....so far so good with it. If you do it right...you can have your existing system out in about 15-20 minutes and re-installation, although a little longer....should still go well. All good Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
01-23-2018, 05:15 PM | #3 | |
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
01-23-2018, 06:16 PM | #4 | |
I would be happy to have them available to the membership but its up to the mods It is in a 3 page pdf file... I have sent to several of the guys and I think it has been of assistance. ...lets see what the mods say, their call. All good Coley
01-24-2018, 02:25 PM | #5 | |
70+ ( Old Skool Club )
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
01-24-2018, 11:48 PM | #6 |
Cluster King
If you need any help with this, let me know.
Classic Instrument clusters do need wiring. They need input from oil sender, temp sender and dash lights wired as well as VSS input from trans and tach signal from ign coil. They also need speedometer and tach calibration which is clearly stated in the instructions provided by the company with the cluster. If you want to have a stock style tach cluster built, I can do that for you if needed. Hope this helps, Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
01-23-2018, 10:21 PM | #7 |
A question to ask is whether or not you have an existing gauge instrument cluster or dummy lights
01-24-2018, 10:28 AM | #8 |
The top one is the one I have now. The bottom is the setup I want. Rpm, clock, added, no booster. Pretty much the bottom is the one I want. Wanting to know how to wire that up. Thanks.
01-24-2018, 10:37 AM | #9 |
How did I get this OLD!
Title is a bit misleading. OEM (Original Manufacture Equipment ). Sure looks like you want an aftermarket set up. Lots of guy here should be able to help and have done that conversion.
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023 Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt. |
01-24-2018, 02:23 PM | #10 |
That bottomcluster looks like a Classic Instrunents set up and if that is the case you can get what you need from them and in fact I believe you can get electronic sensors so no wiring needed.
01-24-2018, 10:51 AM | #11 |
I would also assume that whomever sells that aftermarket cluster also provides wiring instructions.
1965 Malibu SS L79 Restoration Page 1965 Two-Door Wagon Project Progress Page 2006 Pontiac GTO Preservation Project Rich Cummings |
01-25-2018, 04:15 AM | #12 |
Thanks everybody for all your responses. I did check and it is a classic instruments cluster. I called them up and they said all sensors and wiring are provided with the exception of One sensor but I forgot which one.
