Boyd Tank
I have a Boyd tank that's 5 to 6 years old new. Can I retrofit a efi pump in the tank or should I use a external pump and corvette filter return? Which one is better live longer?
OLDIRONRACING |
![]() ![]() Join Date: May 2015
Re: Boyd Tank
you might send it back to boyd and let him weld in one of his intank pump mounts...but there are kits you can do yourself. ...nothing wrong with external pump either but the intanks are supposed to last longer...my external is going on 6 yrs now and still going strong...some people fuss about the noise of externals but once cranked you can't hear mine...
#3 | |
Re: Boyd Tank
OLDIRONRACING |
Re: Boyd Tank
walbro 255 with vett filter/reg....
Re: Boyd Tank
If I use a external pump it will mounted up in the frame rail at the top of tank. I've been told that this pumps won't suck they have to have gravity feed and fuel will not run up hill and what happens when fuel level gets low ( 1/2 or 1/4 )
Like the idea of a external pump
OLDIRONRACING |
![]() Join Date: Aug 2004
Re: Boyd Tank
I have mine inside the frame rail just forward of the hump. I don’t have any issues with pulling fuel even when 1/4 tank.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Re: Boyd Tank
mine is mounted 6" above the tank on the frame rail.....never had a issue...I've run mine nearly bone dry before
