Old 02-12-2018, 10:04 PM   #1
thehata1
8 Lug 20 Inch Steelies
Well, I've been looking for some these for a while. Detroit Steel just started making them. I ordered some 20X9s and will post up some pictures here in 3 to 3.5 weeks when they come in.
They also come in 22 inch, but you can't get the beauty rings with the 22s.
thehata1 is offline   Reply With Quote
Old 02-13-2018, 06:04 AM   #2
Aus69c20
Aus69c20's Avatar
Re: 8 Lug 20 Inch Steelies
Looking forward to the pics. Will they take the 3/4 ton caps with clips.
John
69 c20, 396, th400, dana60, ps, ac
Aus69c20 is offline   Reply With Quote
Old 02-13-2018, 09:44 PM   #3
thehata1
They will drill, tap and mount clips so you can use the stock cap. I'm going with 2003ish cap shown in the pic. Here are some pics from Detroit Steel and Penn C10.
Old 02-14-2018, 05:47 AM   #4
Aus69c20
Aus69c20's Avatar
Thanks for the reply. Those 2003 caps look great on them.
John
Old 02-14-2018, 01:42 PM   #5
Jose's 69
What kind of back spacing did you get? I'm debating whether I should get those or waiting for artillery style. For those '03 style caps you just need the threaded lug nuts right?
Jose's 69 is offline   Reply With Quote
Old 02-15-2018, 01:41 AM   #6
Oly72C20
THANK YOU for posting this!!!! That information just made my day!!! I can't wait to see pictures of them on your truck!
Joe
Oly72C20 is offline   Reply With Quote
Old 02-15-2018, 08:20 PM   #7
thehata1
Front: 20X9 5"bs
Rear: 20X9 4"bs
Wish me luck...
Old 02-15-2018, 08:59 PM   #8
Jose's 69
Good luck. Just ordered mine today. Went with 20x9 5.5 b.s. in front 20x9 4.5 b.s. in back. Let's see how it goes.
Old 02-15-2018, 09:17 PM   #9
thehata1
Good luck to you, too. If you would, post some pics here so we can compare the 1/2 inch.
Also, what tires are you going to run?
Old 02-16-2018, 10:09 AM   #10
jjzepplin
jjzepplin's Avatar
In for pics!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 03-08-2018, 07:54 PM   #11
thehata1
Well,
I got 3 of 5 packages today. I just couldn't help myself though.
Old 03-08-2018, 07:57 PM   #12
thehata1
Well, that didn’t work well...
I’ll fix the photos when I’m done.
Old 03-08-2018, 08:20 PM   #13
KevinK7
KevinK7's Avatar
I may need to reconsider my 8 lug wheel options, ...I like the look of these
KevinK7 is offline   Reply With Quote
Old 03-08-2018, 08:27 PM   #14
Jose's 69
Nice!! Just got mine powder coated. Should have them on tomorrow. Trim rings should arrive tomorrow also.
Old 03-10-2018, 07:20 AM   #15
jjzepplin
jjzepplin's Avatar
Well that just looks fabulous! What tires are you going to get?
Old 03-08-2018, 09:37 PM   #16
thehata1
Jose,
How did that cap clear the rear axle? I'm having hell with mine.
Old 03-08-2018, 09:49 PM   #17
Jose's 69
I think yours are a bit different. Mine fit good. Might have to trim the rear ones on the little stems inside. I was able to get the plastic nut to catch on the rear ones but didn't turn a whole lot. They're off 88-99 truck I think.
Old 03-08-2018, 10:01 PM   #18
thehata1
I may end up swapping to your style then. I had to get some dually caps for the rear. But, plastic caps don't hit the lug threads...
Old 03-08-2018, 10:21 PM   #19
Jose's 69
Can you trim the base to make them shorter? I thought I read some posts of people doing that.
Old 03-08-2018, 11:31 PM   #20
Aus69c20
Aus69c20's Avatar
Wow they look amazing.
I have to go and convince my wife that they are a necessary safety item for the truck.
John
Old 03-09-2018, 10:48 PM   #21
thehata1
Thanks, John. Should have them mounted tomorrow.
Old 03-09-2018, 11:22 PM   #22
KevinK7
KevinK7's Avatar
hata/Jose,
...just curious for your respective trucks, what sort of drop are you running (front and rear)? I'm considering these wheels and want to be sure things clear.
As well, please post pics when tires are mounted
Thanks,
Kevin
Old 03-10-2018, 12:29 AM   #23
Jose's 69
I did 2.5 inch drop spindle in front and 1 inch lowering spring. In the back I have a 4 inch drop spring and 1.5 inch lowering block.
Old 03-16-2018, 04:55 PM   #24
thehata1
Originally Posted by KevinK7 View Post
hata/Jose,
Thanks,
Kevin
Kevin,
To my knowledge, the front end is not lowered. I'm lowering the rear end this weekend. I'll post some before and afters.
Old 03-10-2018, 07:11 PM   #25
thehata1
Here it is all shoed up. I named him Pappaw. Still waiting on the beauty rings. Hopefully they’ll get here Monday. I'm going to lower the back about an inch. I plan on towing with this truck.
Wheels are 20X9 all the way around. 5 inch backspacing in front and 4 inch backspacing in rear. Tires are Continental 275/45R20. I chose Continental because of availability in the size I wanted and they’re asymmetrical, so I can rotate sides.
And, yes, the bed is not set straight. I’ll fix that soon.
