Old 03-15-2018, 09:01 AM   #1
Steve Cole
Dumb Question; But Humor Me
Is there any particular reason the steam tube discharge comes from the drivers side? Is it because the way the coolant flows through the engine it is easier to evacuate from the drivers side? or was it just a flip of the coin that it ended up there? Science or happenstance? In my case, with the new lines, it would be more convenient to exit from the passenger side unless there is a reason not to. Thanks.
Steve Cole is offline   Reply With Quote
Old 03-15-2018, 09:05 AM   #2
mongocanfly
mongocanfly's Avatar
Re: Dumb Question; But Humor Me
I'm going with coin flip....
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 03-15-2018, 09:20 AM   #3
ls1nova71
ls1nova71's Avatar
I'm sure it was because it was easier to rout through the throttle body and then to the radiator. I flipped mine around and bent it to fit and works fine.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 03-15-2018, 10:42 AM   #4
Steve Cole
Good to confirm, thanks!
Old 03-15-2018, 12:39 PM   #5
davepl
davepl's Avatar
Not saying it's the answer, but one thing to remember is that the cylinders on one bank are set backwards relative to the other bank (by one rod width).
Perhaps there's a greater accumulation of steam on the one with the bigger coolant reservoir at the front of the bank?
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 03-15-2018, 01:31 PM   #6
kipps
I'm in the process of pulling a 2010 LMG engine from a Tahoe. The steam line comes from the passenger side head and goes directly to the radiator.
kipps is offline   Reply With Quote
Old 03-15-2018, 07:47 PM   #7
Steve Cole
That's good to know! Thanks.
Old 03-15-2018, 03:30 PM   #8
Clyde65
Clyde65's Avatar
I don’t know if true but I was told that since the coolant is pushed through the motor front ps lower side, the steam port was on the higher side because of possible air pockets.
Idk really.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-15-2018, 07:49 PM   #9
Steve Cole
Idk really.
Hmmmm... now you have me thinking...
Old 03-16-2018, 03:31 AM   #10
ls1nova71
ls1nova71's Avatar
Overthinking sounds more like it.......
Old 03-16-2018, 03:57 PM   #11
Steve Cole
It certainly wouldn't be the first time I over thought something!
Old 03-16-2018, 07:44 PM   #12
nsb29
nsb29's Avatar
No matter how you look at it you still have a Steamport coming from both heads I don’t think it cares were it goes to from there
nsb29 is offline   Reply With Quote
Old 03-15-2018, 04:07 PM   #13
sprint_9
sprint_9's Avatar
There are a handful of different variations of these crossover tubes specific to the application for the vehicle the engine was installed in.
One style has a tee right in the crossover tube.
sprint_9 is offline   Reply With Quote
Old 03-17-2018, 08:33 AM   #14
homemade87
Attachment 1763503
You guys are way over thinking this . The reason it was on the drivers side was so it would enter the throttle body on the drivers and exit the pass side to warm the the throttle body in cold climates . If you intent to eliminate the coolant in the tb just run it how ever you want . Does not matter , just as long as it is hooked up to get rid of the air pocket that can form in the head .
homemade87 is offline   Reply With Quote
Old 03-17-2018, 11:19 PM   #15
Steve Cole
'Nuff said! Thanks for all the responses!
