04-18-2018, 09:31 AM | #1 |
Timing a 305
I have a leaking front seal and timing cover seal. Plan on taking balancer and cover off, clean parts up, and swap seals. My question is if i leave the timing chain alone and mark the balancer before I take it off and reinstall it in the same place will that affect the timing?
04-18-2018, 10:02 AM | #2 |
Re: Timing a 305
No. Your balancer has a key way and can only go on one way. The only part that might get messed up is if you have an adjustable timing pointer. Take a cell phone picture of it before you remove it, the timing cover and pointer. Then, when you put it back together, you can line everything up. Other than that, you should be fine. However, you are concerned, you can rotate the engine by hand so that the distributor is pointing to the #1 cylinder. Again, take pictures. They help
04-18-2018, 10:10 AM | #3 |
Re: Timing a 305
I recommend installing a new chain kit, and possibly new balancer. Your chain probably has some slack. That way if you have issues later, that has been done and no worries.
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet Mopar by Birth Chevy by Choice |
04-18-2018, 05:05 PM | #4 | |
Re: Timing a 305
The Achilles's Heel of the enthusiast. |
04-18-2018, 05:47 PM | #5 | |
Re: Timing a 305
04-18-2018, 06:21 PM | #6 |
Re: Timing a 305
Lighten up! It's just a little humor, with a dose of reality tossed in. I know what I'm talking about. I just spent upwards of $5k replacing a leaking intake manifold. Gained about 100 hp in the process. Lol...sigh.
04-18-2018, 10:21 AM | #7 |
Re: Timing a 305
Thanks for the quick replies! I do plan to take pictures of everything for reference. Your probably right about the chain, however I don't know how to time an engine or have the tools to do it so thats why I'd rather not get too deep into it. Just want to fix the oil leaks.
04-18-2018, 10:32 AM | #8 |
Re: Timing a 305
The timing gears both have a punch mark on them.
when you get the cover off,just line the marks up pointing to each other in the center by turning the engine. then,you just have to remove the old gears/chain and install the new gears/chain.keeping the marks in the same place. Done deal! Mike. |
04-18-2018, 12:02 PM | #9 | |
Re: Timing a 305
04-18-2018, 12:16 PM | #10 |
Re: Timing a 305
When I replaced seals, chain kit, could not get pan to reseal and had leaks. Had to replace pan gasket to resolve leak.
04-18-2018, 10:34 AM | #11 |
Re: Timing a 305
So if i just line the dots up then I won't need a timing gun and all that?
04-18-2018, 11:41 AM | #12 |
Re: Timing a 305
04-18-2018, 02:41 PM | #13 |
Re: Timing a 305
Yes I was aware of the oil pan. Hoping it won't be to much trouble. May be a good idea to go ahead and change that seal as well.
04-19-2018, 09:12 AM | #14 |
Re: Timing a 305
Ha! Wont be going down the rabbit hole. Plan to spend as few dollars as possible.
04-19-2018, 04:27 PM | #15 |
Re: Timing a 305
One thing you might want on hand is a new balancer or speedi sleeve in case there is a groove in the snout of the balancer and you can minimize down time.
04-19-2018, 07:53 PM | #16 |
Re: Timing a 305
Recommend a true-roller double roller replacement chain. They aren’t expensive, check out summit. They carry Cloyes and others. Don’t get anything with neoprene teeth.
04-21-2018, 09:03 PM | #17 |
Re: Timing a 305
I used to loosen the first few oil pan bolts on both sides before removing/installing timing chain cover. Seemed to make things a little easier.
