07-14-2018, 03:20 PM | #1 |
Radiator Core Support Bushings?
I'm looking for core support bushings for 63 C10.
I think they just leather pads in there when I pulled it apart years ago. What are you guys using? Also is there a place to get them where I dont have to pay more for shipping than what the parts cost? Thanks |
07-14-2018, 06:39 PM | #2 |
Scrapper 1
Re: Radiator Core Support Bushings?
Best off make a list of parts you need and buy them all at one time Then the shipping it more better
07-14-2018, 07:06 PM | #3 |
Assuming that the 63 uses the same ones as 64,5,6 which is what I'm familiar with, Be aware that the top and bottom ones are slightly different. Factory bottoms have a divot to clear the rivet, while tops do not. Some aftermarket ones do not have this feature, so is worth paying attention to. A correct bottom will work fine on top, but a top will not fit well on the bottom.
Hope this all makes sense, Tom
65 short stepside K10 292-SM420-T221 8 lug closed D44 front NoSpin HO72 4.10 rear |
07-15-2018, 12:29 AM | #4 |
60-66 Nut
The radiator support bushings are the same '60-'68.
https://www.classicparts.com/1960-68...info/78%2D625/
07-15-2018, 07:37 PM | #5 | |
07-15-2018, 08:43 PM | #6 |
They go between the core support and the frame rails.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
07-16-2018, 12:41 AM | #7 |
Oops, I was thinking of wrong part,
Never mind.
07-16-2018, 09:43 AM | #8 |
I built these out of aluminum, did not see the need for isolation.
07-16-2018, 09:52 AM | #9 |
Moderator
And you could sell those "if" they were the correct height for every truck. I dont know the answer to that myself.
