Vent Windows
72 C10. I rebuilt the vent windows years ago - so long ago that I can’t remember what I did. Duh. It’s so difficult to close them that I just leave them shut for fear of breaking the glass. Is there an adjustment someplace? Thanks
Re: Vent Windows
I am also interested in what you come up with. The ones I rebuilt pivot fine but the front bottom corners will not pop in to the weather strip very easily. Is that the same problem that you have?
68 c10 swb stepper 68 c10 swb stepper 67 c10 lwb 06 gmc duramax |
![]() Join Date: Dec 2013
Re: Vent Windows
The only adjustment on vent windows is the spring tension on the bottom pivot shaft , Too tight they won't open and close easily ,Too loose and they'll flop around and not stay where you want them . use cation it's easy to twist the shaft right off the vent window frame .They have to come back out to adjust .
Re: Vent Windows
Thanks for the replies. After checking closer, I think the problem is the stiff weatherstripping in the front corners. They definitely don't leak! I'm going to soak them up with some silicone spray for a few days and see if that helps. Maybe a touch of dielectric grease too.
Re: Vent Windows
Problem is that the back of the vent windows don’t line up with the rear vertical support (the front track of the side windows). They’re tipped, so the top of the vent window and the front curved corner don’t want to go into the weather stripping. Not sure how to fix that. Can I bend the tab that has the rivet?
#6 | |
The Older Generation
Re: Vent Windows
Read this thread. It is three pages long but you pretty much have to read the whole thread to get all of the useful information. http://67-72chevytrucks.com/vboard/s...d.php?t=660294 All vent window gaskets are not created equal..... LockDoc
![]() Join Date: Oct 2016
Re: Vent Windows
Mine are closed and don’t leak, I’m afraid to touch ‘em
72 White Cheyenne, The Ghost |
