08-10-2018, 04:14 PM | #1 |
K10 stock suspension measurement?
Trying to figure out what lift is on my '70 K10. Anyone have the measurement from top of spring to bottom of frame front and back please?
1970 K10 1970 C30 1973 C30 1980 K20 |
08-10-2018, 07:32 PM | #2 |
Re: K10 stock suspension measurement?
The victim...
08-11-2018, 02:46 AM | #3 |
oh thats easy... the lift is.......nice might even be very nice.
hard to tell. could you do some more picture. interior and engine comparments pictures are crucial to that calculation |
08-11-2018, 01:27 PM | #4 |
This probably won't help because my K1500 is not at stock height. Front is 8 3/4" and rear is 10 1/4". In front I measured from top of spring right in front of the mounting plate to the bottom of frame. My truck has a Tuff Country 2" spring lift that to me looks more like a 4" lift. Tires are 32x11.50 Cooper Discoverer, that are 30.4" in actual measured height.
1972 Blazer Highlander 1971 GMC K1500 SWB (sold) 2004 Corvette Z06 CE |
08-11-2018, 07:25 PM | #5 |
How tall are the blocks on the rear spring perches.
08-11-2018, 08:51 PM | #6 |
There are no blocks on the rear, truck is lifted by only leaf springs front and rear.
08-11-2018, 09:15 PM | #7 |
I have 4in lift blocks. I can measure from the spring to the frame in the am for you
08-12-2018, 09:33 AM | #8 | |
08-13-2018, 08:22 AM | #9 |
I have a 4 inch lift on my 72 K10. I can take some measurements tonight and let you know what I have.
1972 K10, 350/SM465/NP205, 4 inch lift, 35x12.50s on 15x10 wheels 1976 K20 crew cab, 350/Ranger/SM465/NP205 |
08-13-2018, 12:56 PM | #10 | |
Thanks!
08-17-2018, 07:32 AM | #11 | |
One thing to consider, measuring from the top of the spring plate or spring pack to the frame would vary with the thickness of the spring pack, and spring pack thicknesses WILL vary between manufacturers and vary with the height of the lift. For example, the factory spring pack, a 2 inch lift spring pack, and a 4 inch lift spring pack may all measure different thicknesses. So I measured from top of axle tube to bottom of frame and this is what I have: Front 13.25” +/- Rear 12.5” +/- This is a 1972 K10 Tuff Country 4 inch lift Tires are 35 x 12.50 Wheels are 15 x 8
08-12-2018, 09:32 AM | #12 |
Here ya go.
08-13-2018, 03:16 PM | #13 |
20' Daredevil (Ret)
Another measurement that may not help, but hey, every scrap of info just might add up to something useful.
My K20 has 2.5" Softrides up front. Measuring from top of spring right in front of the mounting plate to the bottom of frame, the passenger's side is 7 5/8" and the driver's side is 7 3/4". My rear springs are kind of a mishmash so I didn't bother to check (stock springs + AALs + Hellwig overloads).
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
08-14-2018, 06:49 AM | #14 | |
08-14-2018, 03:51 PM | #15 |
Mine is 8" on the front and 9-3/4" on the back. Back springs are good but I need to get new fronts and want to keep the same stance. Still not sure what to get?
