08-19-2018, 09:47 AM | #1 |
WTB Blazer hatch
WTB a nice Blazer hatch. I am looking for an un-repaired original hatch for my 1972 Blazer.
08-19-2018, 05:27 PM | #2 |
Re: WTB Blazer hatch
I have this one looks like there is a crack around one of the catches but there is so many layers of paint its hard to tell also looks like the corner is starting to separate. Doesn't appear to have any other cracks around the normal areas. The handle area does have a missing pieces but will be hidden by the handle. I can get more pictures if needed 400 plus shipping. If interested send me your zip and I will get you a shipping quote guessing around 100 shipping maybe cheaper if you don't need the glass.
08-19-2018, 05:29 PM | #3 |
last pics
08-19-2018, 07:07 PM | #4 |
I was hoping for an un-damaged one. How bad is the cracking? What does the outside look like across the bottom ?
08-20-2018, 01:58 PM | #5 |
Here is a couple more let me know if you need anymore. I took a couple of the crack with and without the flash the blazer is in the garage the lighting isn't the greatest.
08-20-2018, 01:59 PM | #6 |
last
08-20-2018, 11:09 PM | #7 |
No didn't try to loosen the bolts. I think the threads where the handle bolts are good but will double check. That's the only one I've seen but it does have a lot of paint on it. I can get you some pictures of the corners by the glass. I may have plates if they are rusted I've replaced them before they are only pop riveted in I'll check tomorrow. I'm getting ready to part that blazer so I can take the hatch off and get a lot better look at it in a couple of days.
08-21-2018, 01:10 AM | #8 |
Hello again, does that Blazer have a jack set in it you want to sell?
08-21-2018, 12:59 PM | #9 |
08-21-2018, 01:28 PM | #10 |
The nuts for the handle are fine I actually heated them up when I removed the handle. Here are the pictures of the corners the paint definitely has cracks just don't know if its because of the paint being so thick or other issues. I didn't look for the plates but if your still interested after these pictures I will look.
08-21-2018, 01:29 PM | #11 |
last
08-21-2018, 05:11 PM | #12 |
08-21-2018, 05:41 PM | #13 |
