Old 11-13-2018, 01:49 PM   #1
Classics Fan
Idle Issue
My 1971 Jimmy with the original 350 has recently developed a problem at idle. It runs fine for a minute or so then slowly begins to decrease to the point of running rough and threatens to die without feathering the throttle. When I do that it has some initial hesitation as well. The problem seems to have developed suddenly, not progressively. It runs fine down the road, no lack of power or ignition miss. Any thoughts or ideas on what could be causing the idle issue? TIA!
Classics Fan is offline   Reply With Quote
Old 11-13-2018, 01:58 PM   #2
SeventyOne
Re: Idle Issue
Whats your idle RPM?
Could be a vacuum leak.
SeventyOne is offline   Reply With Quote
Old 11-13-2018, 02:44 PM   #3
lks dcvn
lks dcvn's Avatar
Re: Idle Issue
lks dcvn is offline   Reply With Quote
Old 11-13-2018, 04:32 PM   #4
Classics Fan
No tach. My best guess is around 800 RPM in park and 500-600 in drive. Vacuum hoses are in good condition but I will double-check the connections. Thanks for the suggestion.
Old 11-13-2018, 05:07 PM   #5
SeventyOne
Re: Idle Issue
Next i'd inspect/replace the plugs.
Old 11-13-2018, 08:37 PM   #6
Classics Fan
Mad remote troubleshooting and diagnosis, SeventyOne! I found the vacuum line to the PVC valve disconnected at a tee. Reconnected and it runs like new again! Thanks, and I appreciate everyone’s input! Hope to repay with some good advice of my own to someone in need in the future.
Old 11-13-2018, 08:41 PM   #7
SeventyOne
Re: Idle Issue
Awesome glad it was a cheap and easy fix!
Old 11-14-2018, 02:54 PM   #8
lks dcvn
lks dcvn's Avatar
Re: Idle Issue
Old 11-13-2018, 03:07 PM   #9
geezer#99
geezer#99's Avatar
Re: Idle Issue
It’s the weather!
Cooler moist air is the problem.
It creates a colder intake.
Cold fuel vapour inside the intake reverts back to a liquid. The liquid gas puddles in the intake. Some vapour gets to the chamber but is too lean to support god combustion. It runs rough.
Cure is a heat soak. Usually when it starts to run rough if you shut it off for 5 minutes and wait for the hot air in the lifter valley to heat the intake then you’ll be good to go.
geezer#99 is online now   Reply With Quote
Old 11-13-2018, 04:35 PM   #10
Classics Fan
Originally Posted by geezer#99 View Post
It’s the weather!
The problem persists regardless of ambient and/or engine temps.
Old 11-13-2018, 06:39 PM   #11
geezer#99
geezer#99's Avatar
Re: Idle Issue
Ah!
So it happens all the time, not just when you start it cold.
That makes it easier!
I think I know what it is!
Old 11-13-2018, 07:15 PM   #12
Classics Fan
Ah!
I think the problem is solved, pending a test drive in a few minutes. I’m still interested in hearing your thoughts.
