11-21-2018, 08:39 PM | #1 |
Junior Member
1970 rearend
i am looking for a posi rear end for my 1970 gmc .i have the chance to buy one from a 1978 blazer with 4.10 gears .can i install this center section in my housing or is it to new?
11-22-2018, 12:30 PM | #2 | |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: 1970 rearend
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
11-22-2018, 12:57 PM | #3 |
Junior Member
Re: 1970 rearend
thank you that shows the difference know what to look for now
11-22-2018, 01:06 PM | #4 | |
Re: 1970 rearend
If the Blazer is a 12 bolt you can swap the parts out. Buy the book on rebuilding 10 and 12 bolt Chevrolets. Check the pinion depth in Blazer 4.10 unit. Check the backlash in Blazer setup. Remove c-clips and pull axles. Remove carrier and ring gear. Remove pinion gear. Put pinion gear in '70 housing. Check pinion depth. Adjust to match what it was in Blazer housing. Put carrier and side shims in same as they were in Blazer housing. Adjust backlash. BUY THE BOOK THAT TELLS HOW TO DO THIS AND SHOWS THE TOOLS YOU NEED! I encourage everyone to do as much work as they can for themselves. But this job needs a little more info than you will get from asking on a message board post IMO.
Tags |
rear end |
