06-11-2019, 12:54 AM | #1 |
1988 R30 VIN Frame Location(s)?
Hey guys, bought an original California Truck, but it has been registered out of state for the last decade. Took it to the DMV for a VIN verification, which it failed due to the door VIN GVWR decal being faded beyond readable. So, unless I find someone that will reproduce the decal (thus been unsuccessful), I am forced to have the CHP do their inspection which includes finding the frame VIN. Although I have little doubt the truck is sitting on its factory issued frame, I was warned buy the CHP inspector himself that if it doesn't match, I will not be leaving with my truck.
So.....where should I be looking? My Internet searching has been unfruitful. I didn't see it anywhere on the passenger upper frame rail facing the bottom of the body, at least not in forward of the passenger side fuel tank and the firewall. The truck is a square body 3+3 (crew cab) dually. 2wd. I appreciate any help in advance. Edit: The dash VIN plate is clearly readable. CHP wants to see the frame VIN.
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 Last edited by Ford Assassin; 06-11-2019 at 10:15 AM. |
06-11-2019, 05:56 AM | #2 |
Next!
Re: 1988 R30 VIN Frame Location(s)?
VIN should be located in the dash on the drivers side at the base of the windshield
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
06-11-2019, 06:23 AM | #3 |
On both my 88s (one R30 and other one a V30) the frame VIN is on the top of the passenger side frame rail right by the fuel sending unit. My 84 K1500 and 87 R10 has it in the same place also, so it should be there.
06-11-2019, 06:42 AM | #4 | |
The original poster's crew cab would have been built in Flint. Edit: I just realized when I ran the area that stamped the VINs: it was Flint Line#2 (Blazer and Suburban). That might be why I can never remember where it goes on the pickups, which were built on Line 1. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
06-11-2019, 07:08 AM | #5 | |
The only one I know off the top of my head is the V30, which is a Janesville (sp?) truck. I had to go thru the same with it as it hadn't been registered in 10 plus years and the owner before me had passed. I am on vacation so don't have the VINs in front of me, but will try to remember to check when I get home |
06-11-2019, 07:47 AM | #6 |
This is more my curiosity - are they not able to use the VIN that is on the dash for verification?
06-11-2019, 10:12 AM | #7 | |
You were joking, right? California VIN verification requires TWO metal stamped locations. First being the dash. The second being the frame.
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 Last edited by Ford Assassin; 06-11-2019 at 11:25 AM. |
06-12-2019, 12:19 PM | #8 |
Active Member
I have a frame from a 1987 K5 Blazer, the VIN was on the passenger side of the frame
06-12-2019, 08:32 PM | #9 |
Moderator
The frame VIN is often only a partial.
Hopefully they aren't expecting a full VIN
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
06-12-2019, 09:12 PM | #10 |
there mostly looking for the build sequence as the rest is kind of normalish i would think .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
06-12-2019, 10:40 PM | #11 |
Moderator
You could check with these guys on door jamb data decals
https://gbodyparts.com/product_info....oducts_id=3196
