06-16-2019, 02:56 PM | #1 |
Fuel pump pushrod won't budge
(85 C10 305)
I pulled my old fuel pump cleaned and prepared everything. I tried using needle-nose pliers and thin screwdriver to try and pry the pushrod up but it is not budging. What do you think is going on here? Should I attempt to take that pushrod plate off to try to get to it? |
06-16-2019, 03:50 PM | #2 |
Re: Fuel pump pushrod won't budge
I use a hacksaw blade to get under the end of the rod to get it started up. I have never had any luck with needle nose pliers on the rod.
06-16-2019, 04:12 PM | #3 |
they are tricky for sure at the angle there at in a tight hole with oil on them .
also lots of people dont know you can pull the bolt from the front face of the engine in the area of the pushrod tube and install a longer bolt to hold it up in place as you get the new pump installed . then remove the long bolt and reinstall the short bolt . good write up http://www.crankshaftcoalition.com/w...k_Chevy_engine
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
08-29-2019, 01:50 PM | #4 |
08-29-2019, 07:10 PM | #5 |
08-29-2019, 08:01 PM | #6 |
Ok, I took the bolts off the cover and somehow that loosed the pin from it's resting position, from there I was able to scoot a bent hacksaw blade in there and push it out of the way.
A couple of points: - Hacksaw blades are not automatically bendable. You need to look for the ones that are marked flexible and even then I would heat them before bending. - Not everyone's small block has the holes for the long bolt trick, I know mine doesn't - That mine coupled with the awkward position of the mounting bolts makes for a job that should be a snap into a very difficult job. Whoever designed that crap needs to go back to engineering school. |
06-16-2019, 09:08 PM | #7 |
Oh yeah, fun times getting that rod up. I usually start trying to twist it with my index finger. If I get it to turn a little it will usually start moving up. Then I use the long bolt trick to hold it up.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
08-29-2019, 01:52 PM | #8 |
I can not budge it with my finger that's the thing it feels like it is stuck it doesn't move at all, what about removing that bottom cover plate to get to it? I really need some help here.
08-29-2019, 02:52 PM | #9 |
Won't hurt anything to take that cover off, the push rod is most likely resting against it anyway.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
06-16-2019, 11:29 PM | #10 |
Thanks for the heads-up on the long bolt trick. I ended up using thick transmission assembly grease to hold the pushrod up when I replaced the pump, but I'll be sure to keep that bolt in the truck's emergency stash of assorted tools and fluids.
A few Fords and a couple of Chevys |
06-17-2019, 09:47 AM | #11 |
Many oil leaks have been misdiagnosed because of that missing bolt or no sealant on the short bolt.
06-17-2019, 11:00 PM | #12 |
X2 on the hacksaw blade
06-18-2019, 10:17 AM | #13 |
Neat idea on the longer bolt. I had a real bear of a time on the fuel pump twenty years ago on the '86 Suburban I used to have. Only later did I learn of the old trick of using grease to hold up the rod while installing the pump. That would've definitely helped on my 350.
Semper Paratus |
08-30-2019, 10:19 AM | #14 | |
Moderator
Around 1981 or 82 the 350 in Dad's 1978 G20 van needed a fuel pump. I had a devil of a time with the pushrod.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
08-29-2019, 02:28 PM | #15 |
I’ve used long nose needle nose pliers before.
Gripped it, lifted it and slid a hacksaw blade in so it wouldn’t get stuck down again. |
