06-23-2019, 09:22 PM | #1 |
WTB 71 AC wiring pigtails/parts
I need the connector and about 5" pigtail for both-
Ac switch in dash And the connector that plugs into the blower motor relay under glovebox. Mine are ruined. And if someone has the clips that hold the sending unit wire to the top of the gas tank. I need a few of these. Also, the flap door inside the hvac unit under the dash. My flap is broken.
1969 Shortbed in progress 1982 short step, few suspension and motor upgrades.getting a 468 1978 Shortbed fleet side bonanza fully loaded 1978 k20 Silverado loaded.currently engine-less 1989 k10 suburban 9" lift 65 nova And more |
06-23-2019, 10:33 PM | #2 |
Re: WTB 71 AC wiring pigtails/parts
I have a complete ac wiring harness in good shape, $60 shipped which would be better than splicing all those wires. I could include the 3 clips you need.
The broken flap door isn’t replaceable but the diverter valve assembly is available new, most used ones are broken. |
06-24-2019, 12:05 AM | #3 |
Randy, I'll keep that in mind.
My harness is good(wiring is good) it's the black connectors, the housing pieces that are broken. Figured its be easiest to try and get a cut pigtail. I realllllyyyy dont want to rear everything back apart to replace the harness if I can get the black ends and re-pin them. Idk how to go about finding those?
06-24-2019, 05:43 AM | #4 |
I will take the AC harness and parts if Dmartin1 passes if correct for 72’.
Les |
06-24-2019, 10:20 AM | #5 |
aotte, go ahead my friend.
06-24-2019, 01:23 PM | #6 | |
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
06-24-2019, 10:15 PM | #7 |
Sorry I have to slightly retract my previous statement. The only thing cut was the lighting side of it so I’d lean more towards $30 shipped as it’s easiely repairable. My apologies.
