09-05-2019, 04:11 PM | #1 |
63 Panel is ready for an operational test!
I discovered when registering my panel that I purchased it 13 years ago (from a yard in AZ). It sat for a couple of years, but I have been tinkering with it on and off for a long time. Several other projects have come and gone, but this one has endured!
Body-off frame restoration, rebuilt and warmed over 350, 700R4, Silverado seats (with integral seat belts), disc brake front end from a 71 C-10, and a steering column from a 76 C10. New wiring, gas tank, shocks, aluminum radiator, brake lines, etc. I also converted it to clamshell rear doors. Still has considerable "patina" and the interior needs to be done, but we will find out if it is a driver today! Fingers crossed Parenthetically, I installed new Kadron carbs on my 73 VW Panel (2.0 engine) and was so excited about how it ran I decided to try taking it over our local bridge. Carbs worked great. Electric fuel pump crapped out 1/3 of the way over the bridge. Very exciting and very expensive tow |
09-08-2019, 04:44 PM | #2 |
Re: 63 Panel is ready for an operational test!
How did it run? hope you had a nice ride. Post some photos.
09-08-2019, 08:39 PM | #3 |
. Seemed to run well. Rear suspension seemed a little squirrelly, but not inflating the shocks probably didn’t help . Trans seemed to shift well. A few more turns around the pattern and I’ll try a cross country flight. I was pleased the the rest end didn’t make a bunch of noise. I really didn’t do anything to it. Thanks for asking!
Posted via Mobile Device |
09-09-2019, 10:10 AM | #4 |
Panhard bar in good shape?....Also how are the bushings in the trailing arms.
09-09-2019, 11:56 AM | #5 |
Pretty sure I replaced the bushings in the trailing arms. It's been a while so I will double check. Not sure about the panhard. Going to put some air in the rear shocks today and try again.
