09-08-2019, 11:04 PM | #1 |
Dual Fuel tank capacity?
Is there a code on the SPID that denotes the capacity of the saddle tanks?
85 K20. I assume it's 16 gal but since installing my Dakota Digital guages it's seems to be off about a quarter tank when below full. For instance, when it hits 1/4 tank, I fill it up and it takes 15 gallons. |
09-09-2019, 12:13 AM | #2 |
Re: Dual Fuel tank capacity?
Not sure on the spid, but my 83 K20 has dual 20 gallon tanks.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
09-09-2019, 06:00 AM | #3 |
Short of running it dry and refilling it, how do you know that?
09-09-2019, 07:06 AM | #4 |
Nope. Capacity is not noted on the SPID.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
09-09-2019, 10:46 AM | #5 |
all short bed trucks used 16 gallon tanks, not enough room physically for a 20 gallon tank.
you can measure the tank, a 20 gallon tank should be roughly 56 inches long and be almost touching the front rear spring hanger. a 16 gallon will be roughly a foot shorter...43 inches if i remember. |
09-09-2019, 11:22 AM | #6 |
0-90 ohms is the gm sender spec when they work in a perfect world .
and short bed tanks in a long bed get special filler tube steel pipe extension or if someone else swapped them in it would be a looooong rubber hose to reach the tank from the filler .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
09-10-2019, 10:15 AM | #7 |
Fuel gauges are always just an approximation. On one side, filling from the half tank mark it will take ~11 gal, and the other side it is about 9 gal on my truck.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 |
09-10-2019, 10:36 AM | #8 |
^^ This. On my 75, with the original gauge, I had 4 gallons left on E. Had to replace the gauge. Now E pretty much means expect to switch tanks real soon. Same tanks and senders. On a tank that is run dry, I can sometimes get as much as 21 gallons into the nominal 20 gallon tank.
09-10-2019, 10:50 AM | #9 |
Thanks for the info.
So is it safe to assume that shortbeds have 16 gallon tanks and longbeds have 20 gallon from the factory UNLESS someone swapped the shorts into the longbed? I'll probably intentionally run one tank out of gas on purpose and then go to the pump on the other tank. I'll fill it and notate what the guage says at each 1/4 mark and full. I just want it to be on my terms, not in the middle of the freeway. |
09-10-2019, 11:11 AM | #10 |
1987 r/c-10 i parted out for the body was factory twin tank 16 gal on a long bed . had the factory extender pipes for the fillers .
so do NOT think long = 20 and short = 16 ........... or you will be surprised . also this truck had 56" rear springs in a 1/2 ton . hangers were still factory riveted to the frame rails .
09-11-2019, 12:12 PM | #11 | |
09-11-2019, 01:00 PM | #12 |
I just want to know when it is actually about to run out by the guage. My Nissan goes another 100 miles when it hits E, my motorcycle runs out at 3/4.
09-11-2019, 01:16 PM | #13 | |
I used to do that with my '80. K
09-18-2019, 05:48 PM | #14 |
I do this all the time in my 76, but it's an auto. Why the manual trans stipulation?
Current: 84 K30 3+3 SRW (2010), 76 C30 3+3 DRW (2015), 83 C10 Suburban (2018), 89 C20 3+3 (2018), 90 K5 (2019), 89 V30 DRW C&C (2019), 78 "Big 10" (2019), 83 K30 3+3 SRW (2020) Previous: 79 K20 Long Step (03-05), 91 R30 3+3 DRW (11-12), 83 K30 3+3 SRW (13), 86 K30 SRW (16-17), 73 C20 (18), 85 C20 3+3 (18-19), 80 C10 (19-20), 77 K5 2wd (19-20) |
09-11-2019, 01:15 PM | #15 | |
Short bed will always be 16 gallon tank(s). Long bed could be a 16 gallon tank (depending on GVW and other powertrain considerations) but will usually be 20 a gallon tank. K
09-16-2019, 09:43 PM | #16 |
ive seen them only have one tank also just pointing that out. lb with a single 20 gal tank.
09-19-2019, 05:49 PM | #17 |
You will usually have several seconds of partial power before the motor really dies. It only takes a second or so for fuel from the full tank to reach the carb. As long as you are at cruise, you will feel the loss of power well before the engine fully dies. You don't want to be in the middle of a high power merge onto an interstate when a tank runs dry. Between the low fuel level and the high front to back slosh factor for these tanks, you can go from full power to off almost instantly.
09-20-2019, 12:35 PM | #18 |
I recently put some NVU digital gauges in my 81 swb, when the fuel gauge hits 1/4 tank, I pull over at the nearest gas station. Earlier this year I actually ran out of gas when I decided the gauge was lying to me, and I just got one little 16 ga tank, so there was no switching for me.
I am guessing that it is more of an art than a science to get a digital set up to work with an analog sending unit and most of these companies figure close enough is close enough.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
09-23-2019, 09:52 PM | #19 |
Seems to me, back in the 70's there was a rule? that stated GM could only put on 39 gallons worth of fuel tanks in any long bed pick up as a MAX capacity?
Maybe somebody can clarify this? |
09-24-2019, 07:15 AM | #20 | |
Plus - Suburban had a 40 gallon tank, in the rear. K
09-25-2019, 09:55 AM | #21 |
LOL fuel capacity limits...blah!! I just recently provided a customer with a custom rear chassis harness and control wiring kit to run 2 Pollak selector valves to operate 3 tanks....a 40-gallon rear tank and both 20-gallon saddle tanks in a CC dually! A 502/NV4500 is a thirsty beast!!
09-25-2019, 11:25 AM | #22 | |
09-25-2019, 12:09 PM | #23 |
It was a build that required dual Pollak 7-round trailer add-ons as well as a cool mod to the rear markers lights-this required the use of a larger, 1” frame loom and related frame clips w/rosebud clips. Factory style routing and worked out slick!
09-25-2019, 12:38 PM | #24 |
Moderator
Stake body with the side markers?
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
09-28-2019, 10:01 AM | #25 |
Look underneath at the back of the tank. If there is atleast 8-10 inches from the tank to the front spring hanger then its a 16 gal tank. If there is less than 2" its a 20 gal tank. The replacement 20 gal in my 87 is so close to the front hanger that I had to bend the flange that goes around the seam of the tank just a little to clear the hanger properly.
Thank a Veteran. They have sacrificed more than you will ever know! 2003 Chevy Z71 Tahoe 190,500 miles 2002 Chevy Silverado 1500 4x4 230,000 miles 1987 custom built Silverado 4x4 435,764 miles 1985 K5 Blazer 396 bb 4x4 project 1982 K5 Blazer Silverado 4x4 519,348 miles |
