10-17-2019, 02:26 PM | #1 |
Burnouts and 4l80e's
My truck is a '51 with a nice stiff TCI chassis, 9" rear with 4 link, a 2006 Silverado 2500 stock LQ4 6.0 and a rebuilt early 4L80e. I'm running 305/30R20 rear tires so there's a lot of tire on the ground. Only mods to the motor are the Hooker cast headers and K&N type air filter setup. I just had the computer all setup with the truck.
It runs great, starts off hard and accelerates really good, but no burnouts or hardly any real spinning at all. I'm more curious than anything as I see other guys on here with pretty comparable builds smoking the tires. My tuner tells me most are probably running 4L60e transmissions and that the '80 sucks up a lot of power off the line. Of course, he's happy to port the heads, add a cam and bigger injectors, maybe add a looser converter and retune it and guarantees big smokey burnouts! Again, wondering what others' experiences are?
Scott ______________ my '51 build: http://67-72chevytrucks.com/vboard/s...d.php?t=677979 |
10-17-2019, 02:46 PM | #2 |
Re: Burnouts and 4l80e's
If you cant smoke 30 series banana peel tires, you likely have mechanical or PCM tune issues. A stock LQ4 should have no problem boiling them. Have someone competent datalog/eval the truck on-site and if necessary, find another tuner.
Current project 1959 Willys = GEZR TRUK Geezer is a Latin compound word made up of two roots. Gee meaning Urine Stain and Zer meaning your pants are open! FMCDH GBU and GBA http://www.youtube.com/user/aknovaman/videos |
10-17-2019, 08:21 PM | #3 |
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
12-27-2019, 02:04 PM | #4 | |
A looser converter will allow engine torque to hit harder, and bark them pretty hard. You have freeway gears, and 4.11's with your combo as it sits would be the key. Combined with a converter would get you there as would roll control or line lock. The gears, and converter would do it anytime you please. Roll control when you set up for it. |
12-28-2019, 02:57 AM | #5 |
I'd put. 4,400 rpm converter in it, have your tuner adjust shift settings and lock up early for less than 50% throttle to keep trans temp down. People get scared of big converters but I used to street drive my 4,900 a lot (honest flash rpm at the track NA, 5,800 on the unit). It's all in the trans tune. That was a 3.73 gear with 315/60/15 drag radials.
I swear by verter over gear and the right trans settings. Your stock 6.0 will be happy all the way around from stoplight WOT to 65-75mph freeway cruises at a nice mellow rpm being you have 3.50 gears. Good luck with traction with said converter at WOT.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
12-28-2019, 11:28 AM | #6 | |
10-18-2019, 08:11 AM | #7 |
A looser converter will help. Also what gear is in the back? The settings on the 4 link and the gear could be combining to dead hook the truck when you hit the gas. A line lock is always a help in busting the back loose.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
10-18-2019, 09:42 AM | #8 |
3.50 in the rear. i think you’re right and it’s not necessarily bad that it hooks and launches hard! I may look at a looser converter at some point.
10-18-2019, 12:10 PM | #9 |
Did you have torque management removed or seriously turned down in your tune? If not that could be a big reason.
Saskatoon, Saskatchewan Canada |
10-18-2019, 01:27 PM | #10 |
Good question - I'll ask the tuner.
10-18-2019, 05:19 PM | #11 |
2x on this ^^^. Also make sure he adjusted the PE table to a more car like setting. Truck engines came with terrible PE settings and it's an easy fix with Hp Tuners software.
10-18-2019, 10:04 PM | #12 | |
Thanks!
12-27-2019, 01:20 PM | #13 |
yea my ls1 4l60 lays them down with 390 gears. glad your up and running scott!!
My build a 49 5 window ls1 4l60e on a TCI chassis http://67-72chevytrucks.com/vboard/s...d.php?t=754926 My travel blog The Wong Winding Road-Adventures of The Chinese Cowboy https://thewongwindingroad.blogspot.com/ |
