![]() Join Date: Mar 2019
WTB eventually OEM 68 327 INTAKE MAN & CARB
Hi, I'm posting this to see what available out there and price. I have a 68 327 Automatic trans with aftermarket intake and carb. I want to restore the engine it back to its original build. My block casting # 3858174
My research says i need: 3919803 intake Cast iron Rochester 4-bbl, riveted oil splash shield, temp sending hold plugged. Also, looking for Original valve covers. One hold per side. (PCV and Fresh air) Thanks guys. again just seeing whats out there and price.
67 C10 Fleetside SOLD 67 C10 SWB Fleetside 67 C20 Fleetside 68 C10 Fleetside 68 C20 Fleetside SOLD 72 k20 Pay Pal: Grant.Furneaux@gmail.com |
![]() Join Date: Jul 2001
Re: WTB eventually OEM 68 327 INTAKE MAN & CARB
Pretty sure I can help out with the valve covers. Have two sets of the earlier 350 valve covers. Need a clean, prime and paint but no dents or dings. Will add pics later to this post. Had to stop and think, do you have oil fill tube in intake or twist cap on valve cover?
Also if needing one I have a Rochester 4GC 4 BBL air cleaner in the parts stash. If interested in it I can get pics taken.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks Last edited by Ironhorse; 12-04-2019 at 07:36 PM. |
#3 | |
Posted via Mobile Device |
Pics of the 4 BBL air breather I have. Measures 4 7/32'' at carb throat opening which is correct for the Rochester 4GC 4 BBL carb. Very nice condition both inside and out minus the dust and dirt accumulation. Air horn is straight with no dings, rubber gasket intact. $55 plus shipping is what I'm thinking. Would do $75 plus ship after a bead blast, prime and paint. Rather hard to find a decent example without a lot of rust. Let me know if have further interest.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
#5 | |
#6 | |
4 BBL air breather SOLD to Furno68C20. PM sent with info.
![]() ![]() Join Date: Sep 2008
I have some intakes. Do you have a casting number and date you are looking for.
I may have valve covers.
#12 | |
The Older Generation
My all original '68 C-20 CST has a 327 & TH400. My research indicates that the correct carb would be #7028212. I thought I read somewhere the the even numbers were for auto transmission vehicles and the odd numbers were for manual. If anyone can confirm this that would be nice too... I will check the number on my intake manifold in the morning. LockDoc
#13 | |
#14 | |
![]() Join Date: Aug 2017
If you like, compare with my build sheet 26 CARB. -8213 (Excel field D6), 1968 327 with M49 (TH 400 Turbo hydramatic) Interesting opinion from here: http://recarbco.com/tech-help/oem-numbers/ T: Transmission. Even numbers are automatic trans, odd numbers are manual trans. Rochester also doesn稚 always follow this rule. This guide is just that: a guide. It is not set in stone, because it is a documented fact that Rochester didn稚 follow these rules 100%. It is for Quadra-jet carburetors only. Rochester also had different numbering systems for their other carbs besides the Quadra-jet. Our thousands of pages of information on this comes straight from Rochester. Keep in mind that just because the OEM numbers between two carbs may be different, it doesn稚 mean they are different carbs. It痴 very possible to have two carbs, their date is 2 years apart, one is for Buick and one is for Chevy Truck, and one is for automatic, the other for stick, and the carbs are identical in every single way, even down to the jets and metering rods. It痴 much more common than you might think. Also, many people think they have to have a carburetor with a certain exact OEM number. This can sometimes be very very hard. Most people don稚 have to have this, they really only need a carburetor that crosses over the same and is identical. You realistically only need an exact OEM number if you are restoring a car back to original condition to enter into a car show.
Best regards GerhardH! Members met: 68 short step, 68bowtie, 72c20customcamper, botmfedr1, C/10 King, Chevyland, cornerstore, dmjlambert, fun in dirt, GMan69, Ol Blue K20 1968 CHEVROLET C20 Custom Camper 50th Anniversary, Long bed (LB) 8', 327 V8, Air Condition (AC), Power Steering (PS), Power Brake (PB), Z62 Custom & Comfort Appearance, Turbo Hydramatic TH 400 http://67-72chevytrucks.com/vboard/s...d.php?t=760400 Last edited by GerhardH; 12-19-2019 at 11:20 AM. |
#15 | |
Thanks for that info Gerhard. I think that scenario is more common than we all think, and not only for carbs. LockDoc
#16 |
![]() Join Date: Nov 2013
I have a 3919803 intake and carb
#17 |
Assembling engine: 04-24-1968
Assembling Car: 05/1968 Set in service 06-29-1968 If you have a look on the protect-o-plate is clear stated that the carburator was a CARTER : C Here a statement from a known Carburator Expert: The numbering rules for Rochester carburetors have a lot of exceptions. One common one is for trucks, where the an odd number is often used for both standard and automatic. This is the case in 1968 where the number 7028213 is used for a 327 in a truck, regardless of transmission. However, in passenger cars in 1968, 7028213 were used for 327 standard transmissions and 7028212 was for automatics. It would be incorrect to have a 7028212 on an automatic equipped 327 truck since the Rochester manual from the period lists only 7028213 for trucks. GM used Rochester and Carter-produced QJets interchangeably. I don't believe that the carburetor source was recorded anywhere when the vehicle was built. However, it is probably true that certain dates are more likely to have one or the other, but this information hasn't been collected anywhere that I know of and exists only anecdotally. Carburetors designed for manual transmissions will normally run lean if used on the same engine and automatic transmission. The carburetors for automatic transmissions are generally slightly richer in the idle circuit to compensate for the fluid coupling losses in the torque converter.
Best regards GerhardH! Members met: 68 short step, 68bowtie, 72c20customcamper, botmfedr1, C/10 King, Chevyland, cornerstore, dmjlambert, fun in dirt, GMan69, Ol Blue K20 1968 CHEVROLET C20 Custom Camper 50th Anniversary, Long bed (LB) 8', 327 V8, Air Condition (AC), Power Steering (PS), Power Brake (PB), Z62 Custom & Comfort Appearance, Turbo Hydramatic TH 400 http://67-72chevytrucks.com/vboard/s...d.php?t=760400 |
#18 |
![]() Join Date: Dec 2015
When I was researching to find the correct carb for my '68 396 engine, I found that the odd 7th digit could have meant manual transmission OR turbo 400. I could be wrong, but believe it has to do with the kick down switch.
#19 |
![]() Join Date: Apr 2017
Bummer, I've got a correct 2 barrel carb intake I pulled off of my 68 327 earlier this year. Good luck!
1968 GMC C2500 Long Bed Fleetside |
#20 | |
- The number on my intake is the same as your research shows. 3919803. Under that is GM 1. The number is just behind the carb. I am the second owner of this truck and it is completely stock.... LockDoc
#21 |
![]() Join Date: Aug 2014
Carb info
Az |
#22 |
Rods, thanks for posting that. That is some great info to file away for future use.
#23 |
So by that chart the carb number I posted in post #7 would be correct for the '67 Chevy with a 327 and auto trans.....
LockDoc
#24 | |
Posted via Mobile Device Last edited by LockDoc; 12-07-2019 at 01:14 AM. |
#25 |
4BBL air breather received yesterday. Thanks again ironhorse!
