Old 03-05-2020, 07:44 AM   #1
TomMLSx
TomMLSx's Avatar
Power Steering Fitting Question...
Did a search, nothing conclusive.
Has anyone had luck converting high pressure side of 80's model steering box fittings to -AN? Want to lose the factory hose/hard line and go straight to -6AN to 18MM o-ring. See link below for fitting. Pretty sure it will work, was just wondering if any of the membership had already done this?
The fitting...
https://www.jegs.com/i/KRC/612/10123000/10002/-1
Thanks in advance,
T,
TomMLSx is offline   Reply With Quote
Old 03-05-2020, 06:06 PM   #2
LS short box
Re: Power Steering Fitting Question...
I always use -6 line and used a fitting like that. Double check that the two ports are same size on the box. Use the high type Teflon lined -6 line on the pressure side.
Old 03-05-2020, 07:35 PM   #3
TomMLSx
TomMLSx's Avatar
Good news, pressure side is 18mm, return side is 16mm. I have alocal shop that can make a pressure line for me....
Thanks for the help...
T,
