Old 03-31-2020, 12:13 PM   #1
G-NUT
G-NUT's Avatar
Clean fuel line connection to Street Demon Carb
Anyone have any pics or thoughts for clean looking fuel line connection to a Street Demon carb?
'84 Suburban C10 Silverado - laying pinchweld to the ground on 22/24.
/Porterbuilt / Accuair / Bonspeed / Landsail / Auburn Gear / Richmond Gear / Moser / Raybestos / ProMaxx / Edlebrock / Street Demon / Taylor Wire / K&N / MSD / KillMat /
SOLD: 1985 GMC Sierra Classic 2500 3+3 Crew Cab Long Bed
G-NUT is offline   Reply With Quote
Old 03-31-2020, 12:20 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Clean fuel line connection to Street Demon Carb
I'm using the inverted flare/nut fitting sold on eBay and Summit for the Street Demon carb. Since it comes out of the carb at a low angle then 90 forward, then 90 down toward the fuel pump. Simple.
Old 03-31-2020, 12:49 PM   #3
The Rocknrod
Moderator
They make one that looks like the Edelbrock that goes forward. The problem with this one is you run a garden hose out of it, unless you get a nut and sleeve and flare the tube that heads to the fuel pump.
Old 03-31-2020, 12:50 PM   #4
The Rocknrod
Moderator
You can use a short piece of rubber and a nipple, 90 the hard line forward.
Old 04-03-2020, 12:52 PM   #5
G-NUT
G-NUT's Avatar
Thank you for the responses. I appreciate it.
The fitting in your first response actually came with my carb. I was thinking I might be able to utilize it.
The Edelbrock looking fuel feed I found in an internet search. It's somewhat of what I was looking for, but I want my lines to be black not polished due to the overall look I'm working towards.
carb, fuel line, street demon
