Is this replaceable?
Can the MAP sensor "housing" be replaced? One of the locking tabs on mine is broken off and it looks like it can be removed and replaced but I tried pulling, twisting, and prying to get it out but it has not budged. Has anyone replaced this before? What's the trick to get it out and where can I get one?
Thanks for any feedback! |
Re: Is this replaceable?
Unless you are boosted, you don't need the locking tabs. The silcone map front will hold the map in there just fine.
Current project 1959 Willys = GEZR TRUK Geezer is a Latin compound word made up of two roots. Gee meaning Urine Stain and Zer meaning your pants are open! FMCDH GBU and GBA http://www.youtube.com/user/aknovaman/videos |
![]() Join Date: Aug 2018
When I replaced my MAP sensor it pressed in pretty tight. So tight I couldn't press it in any further without fear of breaking it. So I think you're fine.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
Sounds good, thanks guys!
I think on one of my intakes it was also like this. I am boosted and have not had an issue. I did push it in good and got that clip to clip then zip tied around the hole arrangement. It worked fine.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
