05-28-2020, 08:12 PM | #1 |
But Found Her 25yrs Later!
WTB Rear portion of a 2-Piece Driveshaft
WTB Rear portion of a 2-Piece Driveshaft that has the HD carrier bearing. I just need the rear driveshaft.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 05-28-2020 at 08:27 PM. |
05-28-2020, 08:46 PM | #2 |
Re: WTB Rear portion of a 2-Piece Driveshaft
What length?
05-28-2020, 09:30 PM | #3 |
What length you got?
05-29-2020, 02:05 AM | #4 |
I've got a pile of them. Can you measure between the front shaft and the rear end? And what diameter is the tube?
05-29-2020, 06:44 PM | #5 |
30.75 inches plus or minus.
05-30-2020, 08:54 PM | #6 |
Closest one I have is 28.5" including the yoke. A longer yoke might do the trick.
05-30-2020, 11:08 PM | #7 |
Thanks for checking.
But yes, I meant to say 30.75 center of u-joint to center of u-joint.
05-31-2020, 02:02 AM | #8 |
Well that's different. I'll have to check again, probably Mon or Tues.
06-01-2020, 08:21 PM | #9 |
I have a couple that are 33" at the center of the u-joints.
06-01-2020, 08:46 PM | #10 | |
Thanks though.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 06-03-2020 at 02:13 AM. |
06-15-2020, 09:42 PM | #11 |
anyone local?
11-20-2020, 01:24 AM | #12 |
Did you ever find one?
1965 c/10 swb 1969 c/10 lwb |
11-20-2020, 08:30 PM | #13 |
11-20-2020, 09:46 PM | #14 |
I believe I have the one you are looking for. I can take a measurement from center of u-joint to center of u-joint and let you know.
11-20-2020, 10:49 PM | #15 |
60-66 Nut
I'm assuming that you need the HD driveshaft and not the light duty driveshaft since that is what is in the pic you posted?
12-19-2021, 05:22 PM | #16 |
Yes, I need the HD one.
11-21-2020, 03:36 AM | #17 |
Yes, when I wrecked my longbed back in the 80's, I just had the rear portion of the driveline shortened.
My uncle welded something that I could bolt to the 62 x-frame donor. My 65 is still on the 62 donor frame. I've been thinking of going back to a longbed, and to do that, I need the stock length of the rear portion of the driveline.
11-27-2020, 04:59 PM | #18 |
I measured 43.5” center to center on the U joints. Let me know if this is what you are looking for
Posted via Mobile Device |
11-27-2020, 05:24 PM | #19 |
Thanks, I need 30.75 inches plus or minus center of u-joint to center of u-joint.
11-27-2020, 08:49 PM | #20 |
Do you know if any 67-72 shafts would work - I have several from trucks I have parted out and would be willing to measure some to see if I have what you need. I see that the length center to center u-joint needs to be 30.75 inches, but I think I missed seeing the tube diameter.
PayPal 1windyridgeboy@gmail.com |
04-12-2021, 10:19 PM | #21 |
Thanks,
Still looking for local.
