![]() Join Date: Aug 2014
Was the steering column rubber mounted up top?
Hi guys I have a non stock steering column in my '54 I think it's a late 50s / early 60s Impala or truck column, anyway it had some funny plastic washers/spacers up top where it mounts to underneath the dash with the half circle brackets, that can't be stock, so my question is, were the stock steering columns rubber mounted up high in that area to absorb any of the vibrations, or is this some previous owner footzpagh or did she just use some plastic as a spacer to build up around those small bushings that go around the vertical bolts?
please and thank you Last edited by Gregski; 05-30-2020 at 11:30 AM. |
Re: Was the steering column rubber mounted up top?
that is stock unless original owner of my truck did the same thing.
This cast unit is what I have always seen with the stock column in AD trucks. This one being in the 1-1/2 ton my my daughter has laid claim to.
2 different angles as I couldn't decide which one I wanted to show. The later columns are a bit fatter than the stock column.
I'm thinking that what you have there is a pipe clamp that was pretty common to snag from the hardware store to hold a column in place.
as mr 48's picture shows, there is a rubber strip that goes between the shaft and both parts of the cast bracket. It helps keep the squeaks down when the shaft moves. also, Ive seen fiber or rubber washers used on the mounting bolts, again to help with the squeaking noise. don't know if they are stock. it does look like you have some kind of pipe clamp holding the shaft to the dash.
49 chevy 3100 3 window. 327 / m21 4 spd, 12 bolt w/ 3:55's Bought in 1973 for $235.00. Had it longer than my wife & Kids!! |
![]() ![]() Join Date: May 2015
Greg...what you have IS the correct mount ...there is a rubber piece that's supposed to be in there between the column and the brackets...
Heres mine
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 05-30-2020 at 07:57 PM. |
From the book....
It shows the cast piece also..,dont know why theres 2 diff styles
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 05-30-2020 at 06:26 PM. |
One of these would help you a bunch...https://www.ebay.com/p/1724985039?ii...xoCnDcQAvD_BwE
#11 | |
Well, today wasn't wasted, I learned something that might actually be useful.
ahem, are you still accepting new membership applications kind sir? and is the Middle Management fast track still an option?
