07-25-2020, 01:16 PM | #1 |
396 experts need help
Hey Guys,
I rebuilt my 396 which is a 69 block. Have the Camaro Heads with a Melling MT6 RV Cam. I ended up Putting Poly locks as the replacement Rocker nuts kept coming loose. Factory ones stayed tight. It has 20-50 oil with Zinc additive and 50 PSI oil pressure at idle with a mechanics oil gauge hooked up. Sounds great when cold. Once it hits 185 - 190 degrees , it idles a little rough and sounds like lifters clacking. Done valve adjustment 10 times. I used 3/4 turn. Tried 3 different oils........ If I missed one of the oil plugs for lifter galley on front of motor behind the timing gear , Would I still have 50 psi ? (Doubt it !) . Plugs are staying white so I am thinking it is also lean. Compression is 150 psi all 8 cylinders.......... What else ? Almost ready to yank it and build another motor. I pulled the Bypass valve this morning and it seems good. No gasket although I do not think that would change much other than possibly mixing a tiny bit of unfiltered oil with filtered oil ? |
07-25-2020, 01:29 PM | #2 |
Re: 396 experts need help
Why such a thick oil ?
Most guys i know run 10/40 or even 5/30 20/50 is a diesel truck oil Do you have headers? Are they loose Have you used comp cam lifters i have heard there fairly noisy |
07-25-2020, 01:35 PM | #3 | |
I have cast manifolds and yes I hear a slight exhaust leak which I am going to address this weekend. But that should not make it idle rough as the noise increases or am I wrong ? Bolts are very tight. Standard melling brand Hydraulic lifters. Started with a chinese brand which I swapped already as at first a few would not pump up. |
07-25-2020, 01:50 PM | #4 |
Is your 50 psi idle oil pressure reading with the engine and operating temperature or cold? What is the oil pressure hot at cruise rpm?
Steve weim55 Colorado |
07-25-2020, 02:35 PM | #5 | |
It is 50 psi weather cold or hot . So cal has not been to cold in the mornings lately. It will go up to 55-65 depending on speed. |
07-25-2020, 02:04 PM | #6 | |
When you changed lifters did you try to break the cam/lifters in again. Sounds a lot like a cam getting wiped. Big blocks are notorious for wiped cams. |
07-25-2020, 02:36 PM | #7 |
When I removed the lifters the cam looked fine. Also it is not noisy until you drive it and it warms up . When it got to 25psi It was even noisier.
07-25-2020, 01:54 PM | #8 |
Have you tried 10/40 ?
Did you check for coil bind on the valves? |
07-25-2020, 03:04 PM | #9 |
Of course the cam looked fine. Lifters and cam wear in togethor.
Changing the lifters likely changed that. Pop the valve covers off and check all the rockers are moving the same. |
07-25-2020, 03:15 PM | #10 |
Ok . I will look when the motor is hot to see if I can spot the change. I cut window in a pair of valve covers for purposes of valve adjustment.
08-02-2020, 08:31 AM | #11 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
This! And I'll add checking with your eyeball is a crude method, use a dial indicator to measure the lift! Only then can you rest assured that all lobes are good, it only takes one bad lifter to wipe out it's lobe. I've had out of the box lifters that failed to pump up because they were failing to collapse presenting zero preload! The Asian machining processes are questionable at best and should never be trusted!
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
08-15-2020, 01:11 PM | #12 |
Well turn out I had a mess. I took things apart again and wonder if this was the case the first time and I just did not notice it ....... 5 Broken valves springs. Broken on the outter spring so the valves were still closing. Also noticed the Valve guides were too loose. I bought these heads ready to go from someone on ebay. They were beautifully cleaned and had all new hardware. Crappy job ! So I am getting new guides and cleaning them up again and getting the correct springs for MTC6 Melling Camshaft. I am thinking they were not the right springs. I should have looked closer but I have never had a broken spring in all my years of automotive since 1992. I have probably worked on 30 different engines of various types LOL. Oh also the valves were all Snow white on the bottom. Lean condition........
Mike |
07-25-2020, 03:33 PM | #13 |
Did you have machinist check valves for your cam lift for binding issues ?
07-25-2020, 03:50 PM | #14 |
07-25-2020, 04:03 PM | #15 |
That is a big check mark of not an issue valve binding can wipe the cam as well
Did the machinist check the new spring rates match the cam too heavy a spring can be hard on the cam too |
07-27-2020, 08:35 AM | #16 |
I'm a bit confused on the time line of events. You rebuilt the motor with Chinese lifters and then you couldn't get them to pump up and so you replaced them.
Was that before you fired the engine for the first time and broke the cam in? When you said they wouldn't pump up what exactly do you mean? What is the part number of the new lifters?
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
07-27-2020, 10:34 AM | #17 |
When you tighten the set screw on poly locks it acks the initial adjustment off. If you tight them up without the set screw sufficiently backed off it will crack the poly lock. Poly locks on hydraulic cams are a pain in general
07-30-2020, 10:48 AM | #18 | |
When I say they would not pump up , I mean you remove valve cover while motor is warm and you are able to lift the rocker arm on the valve with the bad lifter and collapse the plunger. New ones all pop up except what I notice now in the morning after the motor ran last making the noise, the lifters (Not sure how many) are loose and tap for 20 seconds or so. So I think the lifters are not getting enough oil. I really believe this . |
07-30-2020, 11:38 AM | #19 |
I would adjust using the procedure I outlined so you know exactly where they are. Move the pushrod up and down and tighten until you feel zero lash. Then 1/2-1 turn after.
1972 Cheyenne Super 20 Custom Camper 12 Valve Cummins/5spd manual 1972 Cheyenne Super Short Bed 557 Med Olive DK olive 1970 K5 Blazer Dark Gold 1966 Coronet 440 35k mile survivor 1991 Suburban 2500 454/4L80E 2wd 1985 Monte Carlo SS 383 Sbc, t-56 magnum 6spd and Ford 9" |
07-30-2020, 11:50 AM | #20 |
I have the same issue with my 454 with the nuts not holding adjustment and slowly backing off. I just bought a new set of nuts and will swap them out and adjust this weekend. I think the ones that came with the rockers may be junk chinese who knows. I have the comp cams roller tip rocker set
07-30-2020, 11:48 AM | #21 |
laying low
That sounds an awful lot like the lifter issue the early 454's had. After warm up lifter clack appeared and this was with a stock engine. Oil pressure was good but it clacked after warm up. Usually it was on cylinder #1. The GM fix was to drill a small hole in the lifter galley plug at the front of the block next to #1 cylinder to let the hot oil out and fresh oil into the lifters. Dad and I drilled his to cure his lifter clack after having replaced those lifters several times. No more problems. There was a service bulletin back then so this information came from GM in the early 70's.
07-27-2020, 01:00 PM | #22 |
I would just verify your procedure for adjusting the valve lash is correct.
An easy way to do it quickly is mark the distributor body with a marker where each terminal is on the cap. Verify your at #1 TDC with the rotor pointing at the correct terminal. Adjust both rockers on #1 for 1/2-3/4 turn after zero lash. Remember with poly locks to go the half turn or so, back off an 1/8 of a turn and seat the set screw and then turn the rest of the way. You can mark your balancer with a mark every 90 degrees as well and run through the same procedure. Then repeat going through the firing order using your distributor body as reference.
1972 Cheyenne Super 20 Custom Camper 12 Valve Cummins/5spd manual 1972 Cheyenne Super Short Bed 557 Med Olive DK olive 1970 K5 Blazer Dark Gold 1966 Coronet 440 35k mile survivor 1991 Suburban 2500 454/4L80E 2wd 1985 Monte Carlo SS 383 Sbc, t-56 magnum 6spd and Ford 9" Last edited by j_cst_10; 07-27-2020 at 01:07 PM. |
07-30-2020, 10:34 AM | #23 | |
07-30-2020, 11:37 AM | #24 |
Did you re break in the new lifters after you changed them ?
08-02-2020, 09:14 AM | #25 | |
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" Last edited by Ironangel; 08-02-2020 at 09:33 AM. |
