07-29-2020, 10:57 PM | #1 |
Another no start
So I have a 1995 GMC K1500 w/350 tbi
I charge my battery & it reads 12.75V @538 CCA Motor turns over I've tried both fuel & starter fluid in the throttle body So I've assumed electrical. The spark plugs are a year & a half old but look normal on the electrode & still in good shape. Ive swapped out the Ignition Coil for a new one & acts the same as the already installed Delphi & wires (both 2 years old) & fuel pump too. Distributor is a year old. & has ran well since I installed it. Now Im not ruling out bad parts, I went through a hell of 3 distributors all of which were brand new. I drive 100mi twice a month, & the truck sits the rest of the time. But I would like to hear your thoughts & advise. I don't have a second person so I haven't found a way see if there is spark. & Thank You very much. |
07-30-2020, 10:37 AM | #2 |
Re: Another no start
If nothing happens with starting fluid it is safe to assume you have no spark.
I would be betting on the ignition module inside the distributor. I have enough issues I keep a spare in the glove box.Of course it could be cap, rotor etc. but I would still bet on the module being bad. If you have a tachometer and it doesn't move that that is good indication the module in bad. |
07-30-2020, 11:41 AM | #3 |
on seems like spark. I have had a wire break on the distributor that connects near the centershaft. I did not catch it till the 3rd time pulling the distributor trying all sorts on things on my old one.
Only other thing I can think of is their is a second oil pressure sensor/switch on some models that if truck has low oil pressure (it was next to oil filter underneath truck), it doesn't let it start. My 96 had a sensor that was failing that drove me nuts. Not sure if your year would have one or not.
07-30-2020, 11:01 PM | #4 |
Thank you
I do appreciate your input & will take apart the distributor next time Im home & look at the wires. After 3 Distributors I thought I finally had a good one. I was thinking last night coolant senor too, When they go out -200 something degrees & the truck doesn't start. Ha! Since mine's 2 years old & stuff don't lastno more. Going backover the road & won't be back for a month. Will update then & I appreciate y'alls taking a moment out to advise me. |
07-31-2020, 08:10 AM | #5 |
11-06-2020, 05:31 PM | #6 |
It was the distributor! Thanks y'alls!!!!!
Be nice if they could make a good distributor that works or lasts... just saying. |
11-09-2020, 07:48 AM | #7 | |
https://www.summitracing.com/oh/part...50200/overview
Mike |
11-06-2020, 08:16 PM | #8 |
Good to hear you got it ironed out. It is frustrating when new parts are bad.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 11-09-2020 at 08:34 AM. |
