08-03-2020, 12:58 PM | #1 |
Straighten the end of a dock bumper
Hey everyone - I was rear ended and am getting the truck repaired. My dock bumper had previous damage, but id like to get the bed fixed and straighten the OG bumper. Any suggestions on doing it myself? Heat? Hammer?Gas anyone done this themselves?
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
08-03-2020, 01:09 PM | #2 |
Re: Straighten the end of a dock bumper
Your better off taking it to a bumper repair place. Then have jigs, and presses to move that thing. Unless you already have or have access to that stuff, and just want to try.
08-03-2020, 05:38 PM | #3 |
Thanks man!
08-03-2020, 08:31 PM | #4 |
Dock bumper, ey? That's the first I ever heard that before. I picture the bumpers you see on loading docks. I think you found your answer
08-04-2020, 10:19 AM | #5 | |||
"I ain't nobody, dork."
Gary
08-03-2020, 08:41 PM | #6 |
torch with a rosebud tip and a BFH and some patience will fix that
08-04-2020, 09:44 AM | #7 |
If you want it perfect, take it to a bodyshop. If you want to do it yourself and are happy with making it 95% better, I've used this technique multiple times with success.
Wrap a chain around a tree that's at least 8" across. You want the center of the chain around the tree so the two end hooks can attach to your bumper. Hook the chain ends on the bottom edge of the bumper. For that bend you're going to want to position the truck so the tree is at the very corner of the bumper, and have the chain wrapped on the tree just below waist level so it pulls UP and OUT on the bumper. Put the truck in neutral, have about 12" of slack in the chain, and roll the truck away from the tree so that the chain tightens and pulls the bumper up and away from the truck as you roll the truck. (You obviously need to be on level ground for this to work and may need a helper to help push the truck). Each time you do this, watch the bumper as the chain tightens and you'll see if it's pulling at the correct angle and adjust as necessary. By pushing the truck (and not driving it against the chain) you can see what's going on, and have very good control over how much "pull" you're applying with each roll. It will take multiple pulls, and you'll probably be surprised at how much force it takes to pull that bumper back out, but it does work. The key is placement of the hooks on the bumper, placement of the tree, and height of the chain on the tree.
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801 |
08-04-2020, 10:41 AM | #8 | |
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original ) 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
08-04-2020, 11:04 AM | #9 | |
08-05-2020, 12:59 AM | #10 |
Are the struts underneath straight? On my step bumper, from repeated hitting of unseen rear objects in reverse, there was a ''V'' kinked into the drivers side strut.
We took it off the truck, heated the metal and ''corrected it'' with a BFH. Also some sections at the ends had separated, so we welded seams back in. Some silver spraypaint over the welds and it looked great. When we put it back together, we added a Class III trailer hitch.
