08-18-2020, 02:31 AM | #1 |
Help with New Edelbrock AVS 2 install
I got my AVS today and took the holley off, figure I would try something different and see how it does. I can not figure out how to hook up the Auto kick down cable and it seems my throttle cable is a little to long. Can someone tell me if I need some kind of an adapter to be able to hook these up. My old holley carb had the throttle and transmission cable hook to the same arm, along with a return spring. I just cant figure out how to get this hooked up. I figured it would just be a drop in , if I do need an adapter I would have ordered it then. Any help would be really appreciated. Thank you.
I also have the 1 inch spacer I was installing at the same time, but even with that off instill have the same problem. Ughhhhh I cant if someone needs different pictures to have a better idea I can take them. Just really need some help |
08-18-2020, 08:37 AM | #2 |
Msgt USAF Ret
Re: Help with New Edelbrock AVS 2 install
look at the videos. Especially the one about installing the AVS on a 350 chevy engine
https://video.search.yahoo.com/yhs/s...k+AVS+2+instal
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
08-19-2020, 09:15 PM | #3 |
I had to pull the kickdown stud off a Quadrajet and get a Edelbrock Dogde part, cut and fab it for install.
It was the least expensive route to go. Give me a few I will get a pic up for you. Here is a pic of the Edelbrock part I cut down and fabricated. Last edited by toolboxchev; 08-19-2020 at 09:27 PM. |
08-20-2020, 05:43 PM | #4 |
Here is the finished operational modification.
08-20-2020, 07:37 PM | #5 |
08-20-2020, 11:59 PM | #6 | |
08-20-2020, 08:05 PM | #7 |
Here is how I did my 1405 years ago. It is sitting on a 1" spacer. Out of the box, it didn't work. Enough years ago I don't remember what, if any, additional parts I ordered vs scavenging from the old Q-Jet. May have involved drilling one or more holes for the throttle and trans studs.
08-21-2020, 08:36 AM | #8 |
08-21-2020, 11:09 AM | #9 |
I used a bracket similar to this one and had no issues lining everything up: https://www.summitracing.com/parts/edl-8041
72 C10 lwb fleetside -stock 350/350 combo |
09-12-2020, 03:50 PM | #10 |
You guys are awesome! When I get home from the oil field this is the first thing I will try. I got it hooked up to work right before I leave but it is by far not the correct fix. I appreciate everyone's help.
