09-01-2020, 12:27 PM | #1 |
Dome light problems
My dome light in 79 did not work and that has bugged me for a while now. Well I took door jamb switches out and cleaned rust off and used electrical spray, no change. I ordered some door jamb switches but were the wrong size. The thread pattern was to fine but when it contacted metal the courtesy light came on. So I ordered correct door jamb switches and now courtesy light comes on when doors are open but still no dome light. I close the doors and walk away and then the wife noticed the dome light was flickering not fully on just redish across bulb. So am I correct thinking the wiring to dome light originates on drivers side of truck and that is where I should start to look for a short?
79 Chevy 2wd BIG10 350 TH400 |
09-01-2020, 02:05 PM | #2 |
Re: Dome light problems
yes dome light consist of two wires. They run on the drivers side between the seat and the door under the carpet. There is a connection plug where the wire heads from the floor to the roof in the drivers side rear corner. The orange wire is the hot wire. It remains hot all the time even when the truck is not running. The white wire is the ground. It turns your dome on by connecting to a ground. either by the light switch or door switches. start chasing the wires for broken wire. Do you get dome light when you turn the headlight switch all the way to the left? Does your battery run down if the truck sits. If your wife sees a low dim dome light you have a short somewhere in that white wire that is giving it a poor ground. Hope this helps.
09-01-2020, 04:23 PM | #3 |
Dome light work if you turn it on with the headlight switch?
09-01-2020, 04:48 PM | #4 |
No it does not just the courtesy light
09-01-2020, 04:55 PM | #5 |
Check the dome light itself too, the bulb or the connector maybe bad. I had that on both my dome light and rear cargo light. I ended up replacing both lights and the wiring that runs down the B-pillar. I’m glad I did, because the wiring was all dry rotted.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
09-01-2020, 06:01 PM | #6 |
either the socket or the ground wire is broken
09-07-2020, 11:17 PM | #7 | |
As said byTKCR:
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
09-08-2020, 08:16 AM | #8 | |
09-28-2020, 11:52 AM | #9 |
Well I finally fixed my dome light in the truck. I was just about to replace all the wiring from the dome light to the fuse box when a moment of clarity came over me. I went through 3 volt meters because of not being able to get a reading of 12 volts at orange wire. I decided to look at some fuses turned out to be the first fuse I looked at above the orange 12 volt wire that was blown. I am not sure why a fuse controlled a supposed constant 12 volt hot but it did. I did switch the dome light to a LED set up.
Now on to figuring out why my oil pressure gauge reads so low at idle. I am hoping it is just the gauge and not the motor. Is there another place on motor that is easy to get to so that I could hook up a mechanical oil pressure gauge?
09-30-2020, 09:21 AM | #10 |
Glad to hear you got it figured out. Thanks for the update!
