09-12-2020, 08:03 PM | #1 |
1961 crewcab
63- headlights won't work
After a brutal week of changing auto transmissions on the 63 3 times (the one constant was a "good" converter that I didn't know was bad), now the headlights wont work-- they did when I parked it 6 years ago with the bad trans.....
the running lights in the hood, dash lights, and taillights all turn on, just not the headlights--they are still plugged in at the core support--- What should I check, or look for??
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
09-12-2020, 08:19 PM | #2 |
Re: 63- headlights won't work
Dimmer switch would be my first guess. I thought my switch went out, so I bought a new one, but that didn't fix it. Then I remembered that I had disconnected the plug at the core support for some reason and forgot to hook them back up Anyways, I left the new switch in, and about a year and a half later, that new switch went bad. Replaced it with the one I first took out, and that switch has been great ever since
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
09-12-2020, 08:32 PM | #3 |
Times 2 on the dimmer switch. Usually it just the connections as they are prone to corrosion due to their location especially if the cab or windshield leaks.They have pigtails available
09-12-2020, 10:13 PM | #4 |
60-66 Nut
I agree on checking the dimmer switch.
09-12-2020, 11:35 PM | #5 |
1961 crewcab
Thanks guys! Yep dimmer was triggered- bright is no light, and dim the lights come on! Don't know why I didn't think of that.... A little off my game! Haha...
Will have to check out the connections in the daylight.
09-13-2020, 10:15 PM | #6 |
The contacts on the dimmer get dirty so it doesn't work. Cycle the switch about 10-20 times and it should start to work.
