09-13-2020, 11:40 AM | #1 |
Quick Saturday Project, LED Gear Indicator Light
I've been working my way through some final interior details, one of which was a fairly crusty gear indicator. After disassembling it for paint, I noticed that the fiber optic cable was cut right after it exited the steering column, and the bulb holder was MIA. So, I decided to upgrade to some newfangled LED magic. $6 later...magic!
I used these 3mm warm white LEDs which already have a load resistor on them. https://www.amazon.com/dp/B07T8H5527..._1NJxFb125Q541 For power I tapped into the empty inst/gauge illumination spade on the fuse block (right beneath the fuse) with a 1A in-line fuse just in case the wires I pulled ever short. If you decide to do this, make sure you use small gauge wires to power the LED. Pulling 18ga through the steering column was a PITA. The end result is really nice, dims perfectly along with my classic instruments cluster, and should last much longer than the OG bulb/fiber solution. |
09-13-2020, 04:31 PM | #2 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Re: Quick Saturday Project, LED Gear Indicator Light
Nice work!
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
09-13-2020, 06:13 PM | #3 |
Agreed ^, nice work! Your post will help all those future "LED gear indicator light" searches on this board, job well done.
66 GMC Suburban Custom 66 Chevy K10 Suburban |
