12-30-2020, 06:58 PM | #1 |
Active Member
Seized Cylinder Head. Ideas for Removal
So I was just going to do a simple cam swap... now I got a cylinder head that will not come off the block. I have tried everything (prying, deadblow hammer, hydraulic jack, etc.). I know so I need some ideas on how to get this thing off. It’s a 67 c10 with 283 engine with 101k miles. And I can’t drop a 350 in it right now. Thanks!!!
Posted via Mobile Device |
12-30-2020, 07:17 PM | #2 |
Re: Seized Cylinder Head. Ideas for Removal
Pictures please
Why are you taking off a cylinder head for a cam swap on a 283 ? It is an un needed step Is it your intake stuck on have you got all 12 bolts out 2 at the front 2 in the middle and two st the back on each side |
12-30-2020, 07:31 PM | #3 |
Active Member
I’ll get a photo in a bit. Lifters are not coming out due to built up carbon so I need to get the heads out of the way so I can line up my slide hammer on the lifters. Any ideas on pulling out lifters with head attached?? All bolts are out on the cylinder head. Intake manifold is on the shop floor. Photos in a little while.
12-30-2020, 07:55 PM | #4 |
Active Member
Photos... Ideally the lifters would slide right out and there would be no need for lifter removal tools and removing heads and such, but at 101k miles lifters are very stubborn.
12-30-2020, 08:50 PM | #5 |
Can you prop the lifters up pull the cam and drop the lifters out through the bottom?
I would be concerned about damaging the lifters bore if there that hard and built up |
12-30-2020, 08:59 PM | #6 |
Active Member
I was not planning on opening up the bottom end but that could be a last resort. Hell, I wasn’t planning on pulling the heads either but here I am! Maybe it is time for a complete rebuild, just don’t really have the money for that right now after Christmas!
12-30-2020, 09:06 PM | #7 |
Moderator
Make sure you have removed 17 head bolts per side....ugh...I see gmc684x4 beat me to it...
I have seen experienced techs forget the end bolt under each end of the valve cover ! You can get a sharpened hook tool into the cup in the top of the lifter and use a slide hammer to extract.... Try spraying brake clean around the lifter body and let it soak a while.... The lifters on a small block will usually not come up high enough to remove the cam...if they are carboned up badly...
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
12-30-2020, 09:01 PM | #8 |
The heads have 17 bolts each did you get all of them out ?
12-30-2020, 09:04 PM | #9 |
Active Member
Yeah all bolts are out. I triple checked that.
12-30-2020, 09:09 PM | #10 |
A bit extreme, but the cylinder head could be removed with hydraulic pressure. Modify a set of spark plugs to include a grease zerk on each one. Pump the cylinders full of grease, and then add a little to each cylinder in turn until it pops free.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
12-30-2020, 09:23 PM | #11 |
Active Member
FINALLY!!! Used the long screwdriver method again and after much tapping with a hammer I got it broken loose! I did check and recount bolts again just to make sure. Never had one that tough to get off before. Thanks for all the help!!! Time for dinner now!
12-30-2020, 09:28 PM | #12 |
Moderator
Great...
perhaps never been off before.... make sure both the block deck and head surface a flat and dont have any gouges from the screwdriver usage...
12-30-2020, 09:33 PM | #13 |
Active Member
Yeah it’s all original. Been in the family since 67. Finally getting around to sprucing it up a bit. Adding dual exhaust, cam and timing set, new intake manifold and going from a 2-barrel carb to a 4-barrel.
12-30-2020, 09:56 PM | #14 |
Moderator
Remember, its only a little 283....keep the carb size down, vacuum secondaries....a 750 cfm is too big....especially if it is an automatic truck...
Check out this CFM calculator link...street use on a 283 really only needs about a 300 cfm carb....Holley 350 2 barrel on a dual plane manifold will work well... https://www.summitracing.com/popup/c...cfm-calculator Check distributor for wear on the gear and end play....a new hei unit will wake it up...just remember to replace the resistor feed wire with a non resistor... I know you are going to replace the lifters with the new cam...suggest you check valve spring seat pressures while the heads are off... Very important is the breakin oil needed by the cam and the breakin procedure...
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox Last edited by AussieinNC; 12-30-2020 at 10:05 PM. |
12-30-2020, 10:13 PM | #15 |
If it hasn't been apart since 67, I wouldnt stop there...a full rebuild is in order..rebuild kits for sbc dont cost much..especially if you dont need any machine work..but I'm betting you might..
And replace the oil pump as well...remember..its 53yrs old..
12-30-2020, 10:51 PM | #16 |
How big of a wear lip is on the top of the cylinders?
Did you do a compression test before tear down ? Today's oils are better than the oils of yester year they have less waxs and leave sludge behind |
12-31-2020, 01:02 AM | #17 |
Active Member
Wear lip is not that much. I was surprised. Can feel it but barely. I did not measure it. Probably somewhere between .002” and .005” maybe. And I did not even think to check compression. Engine is surprising clean, little to no sludge.
12-31-2020, 02:25 AM | #18 |
What are your short term and long term goals?
Are you keeping it numbers matching ? Being original motor i would change the pan gasket as well and check to see if the lifter bottems have mushroomed out Vortec 350 can be found on the cheap on many late model ones i notice if it has a fuel pump block off plate its a 4 bolt main If you scrounge a used vortec there prone to leaky intake gaskets express vans run them as late as 2002 Ls swaps can be done cheap if you research it and put the sweat equity into the swap |
12-31-2020, 04:50 AM | #19 |
I saw a broken SBC head used as a door stop at Alec's automotive machine shop in Vancouver. Someone had managed to remove most of it without removing the outside row of bolts.
12-31-2020, 07:34 AM | #20 |
Also, did any of the spark plugs have a little rust on them or did you have a cold miss until warmup. The 283 heads (and others) have hairline cracked before between the exhaust and intake valves that once the heads are cleaned can usually be seen. When the engine cools, antifreeze will slightly leak into the cylinder. You may want to magnaflux the heads when the head work is done.
If you have this condition, I think the head is usually a throw away. Maybe you already know you do not have this problem.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T Last edited by dennislbrooks; 12-31-2020 at 07:34 AM. Reason: words |
12-31-2020, 05:55 PM | #21 |
Spray carb cleaner around the lifter & keep working it up & down. There is a lifter removing tool that works real slick. You can use it as a slide hammer or screw. If they are all stuck it usually is varnish built up on he lower portion. If the bottom is mushroomed it is usually only 1 or 2 lifters.
George |
