rear suspension
64 gmc .I dropped my rear suspension 7 inches ,do i need to install the c-notch i bought already or would air shocks be sufficient with out c-notch ,right now i have about 1 inch of travel on suspension before rear end hit bump stops . I would like to load my softail harley deuce in the box in the future it weighs about 700 lbs .
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: rear suspension
With 1 inch of travel unladen, you need to notch it. I'd imagine if you bounced on the rear of the truck your body weight would bottom it out currently and you probably weigh a lot less than the motorcycle does.
#3 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: rear suspension
Drop springs, and lowering blocks? Did you add an adjustable track bar? Did you add rear shock relocators? Personally I would add the c-notch and swap out the coil springs for some 2600 air bags on schrader valves. Then you can air up any time you need to haul anything. Plus you would be able to use quality shocks. I’m not a fan of air shocks.
#4 | |
Re: rear suspension
Re: rear suspension
Thanks for the quick reply .I got lowest spring i could get plus 2 inch blocks and shocks re-locators bracket installed ,love my stance now but no suspension and i wanna be able to load my deuce in the back of the truck if i need too , i know you suppose to c-knotch below 5 inch but heard that i may get away without c-notch if i use air shocks .Just wondering if anybody use air shocks before and i didnt have the bike when i did my suspension .Thanks fellas
![]() ![]() ![]() Join Date: Jan 2018
Re: rear suspension
With only 1" of travel, air shocks won't help enough
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
Who Me?
Re: rear suspension
C Notch and air bags. Even if you do what I call a pipe notch, you gain at least 2 more inches of travel without cutting into the floor. I would also box the frame in that area for more strength.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
