Please forgive me for being blunt, but unless you have done a Cummins swap with the Dodge/Cummins style NV4500/NV5600 into a SQUAREBODY, please keep scrolling in the interest of keeping this thread from being cluttered with irrelevant information.
That being said, I dropped a 94 P Pump 12v Cummins with matching NV4500HD into my 88 crew cab dually. The truck previously had a early GM NV4500 conversion done with a 86 pedal box, etc. The slave types are different, the GM pushes toward the transmission for clutch disengagement and the Cummins slave moves toward the engine for disengagement. Plus the slave travel on the Cummins slave is far greater than the GM slave for disengagement. For those that have done this EXACT swap. What clutch master cylinder did you use? I planned on using the stock Cummins/Dodge slave cylinder. I also have the Cummins/Dodge clutch master that I can modify the pushrod length to work, but the pushrod would be at an angle vs the stock GM squarebody clutch master cylinder pushrod since it mounts at an angle on the firewall. Thanks.
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
Re: Who has done a Cummins swap WITH a NV4500?
Have you tried asking over at 4btswaps.com ?
Also the Cummins forum has a swap section https://www.cumminsforum.com/forums/...abrication.82/
1999 Chevy K2500 RCLB 350 4L80e 2004 Chevy 3500 C&C Dmax Allison |
#3 | |
Good luck, sometimes you have to go hunt for the info you need instead of somebody doing all the work for you.
#5 | |
As far as 'somebody doing the work for [me]', what a joke. I wasn't asking anyone to do anything, but to share info they already discovered. Lastly, guess you missed the 'keep scrolling, unless' part of my initial post. This is exactly the reason....BS clogging the thread for useless responses.
#6 | |
Did a Cummins swap myself years ago, the info you seek is out there.
Catchy title goes here..
![]() Join Date: Mar 2002
Feel free to start a new thread without the bs. All if you please review the site rules before posting again. Thanks
