02-20-2021, 10:50 AM | #1 |
LS swap with frame
Has anybody that has done an LS swap used the whole frame so they could keep the abs brakes, traction control, ETC. Just installed the truck body on the Suburban frame.
02-20-2021, 12:14 PM | #2 |
Re: LS swap with frame
I've seen it done with varying degrees of success. One of the better ones was a guy on here that built a 72 crewcab and put it on a Quadrasteer frame, it turned out really nice, can't remember his username though.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
02-20-2021, 03:05 PM | #3 |
You'll be trading a couple well-documented challenges for a whole grab-bag full of new challenges.
You won't have any driveshaft concerns, your fuel system will be simpler, and the exhaust can stay put, but that's about all you'd be saving. You'll need to mount the brake components from the donor onto the classic cab. The radiator will have to be remounted onto the classic radiator support, so you'll have all the typical fitment problems there. If you're intending to keep all the ABS, traction control, etc, you'll have days of wiring to do, to interface it all with the classic dash. The body mounts will have to be completely fabricated from scratch. It can be done, and I'm sure it has for whatever classic you're working with. But you do have a tougher road to hoe by going this route, though.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
02-20-2021, 03:51 PM | #4 |
Eric,,,Was it drewskiren?
http://67-72chevytrucks.com/vboard/s...ht=QUADRASTEER
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 02-20-2021 at 04:04 PM. |
02-20-2021, 06:57 PM | #5 |
Kipps, I worked in engineering at GM for 30 years, most of it in electrical. So that won't be any problem. I just wanted to keep the other safety items. The hardest part for me will be finding a speed sensor that will run the computer and the cable speedo in the 72.
02-20-2021, 08:48 PM | #6 | |
There are some VSS-to-cable conversion boxes available. They take a VSS signal, and use that to run a motor, which drives a short speedo cable. You can pull a VSS signal off all of the common GM ECM's, and use that to drive an electronic speedometer or the aforementioned conversion box. Personally, I would suggest modifying your original cluster, and install a newer stepper motor instead of the mechanical speedo drive. If you have the background in electrical engineering, it shouldn't be a problem.
02-20-2021, 09:01 PM | #7 | |
02-20-2021, 09:22 PM | #8 |
I'm running Dakota digital ecd-100 boxes on 2 of my swaps..not cheap for sure..but the cost of those is just a blip in the expense column ...and it's cheaper than the other converter box..
I know dd upgraded the box to a newer style with bigger price tag since I bought mine..
02-20-2021, 09:36 PM | #9 |
What I used isnt a cluster...its a convetor box that takes the pulse signal and turns it to a cable drive..then the original speedometer can be used...
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 02-20-2021 at 10:19 PM. |
02-20-2021, 09:46 PM | #10 |
First I have heard about a converter box. I like that idea. I'm just getting started and collecting all available data before jumping in. I am reading Drewskiren thread about his Young Frankenstein truck right now. It will probably take me 2 or 3 nights to get through it.
02-20-2021, 09:53 PM | #11 |
What I used was the ecd-100..im pretty sure it's been upgraded to the 200..and the cost went up with it..
https://www.summitracing.com/parts/dak-ecd-100-2 I used this on my C30 and IH.. This is the 200.. https://www.dakotadigital.com/index....rod/prd886.htm Theres another company that makes a similar unit that coats even more... Yeah, he did a great job on Frankenstein
02-20-2021, 09:26 PM | #12 | |
