69 C10 Bed Install Questions?
Hey Guys Im Going To Install The Bed Onto My 69 C10. Just Have a Few Questions.
Does The Front And Rear Main Sills Bolt Directly To The Frame? No Rubber Isolators Inbetween? Posted via Mobile Device |
![]() ![]() Join Date: Jan 2005
Re: 69 C10 Bed Install Questions?
I have never seen rubber isolators in any of the trucks I've owned. GMCPauls does sell a set though if that is the direction you want to go. Might need to add a grounding strap between the bed and frame afterward if it affects your tail lights.
https://gmcpauls.com/bed_bolt_kits.htm |
Working on my bed now. I have never seen any isolators between the bed frame and truck frame. But I do plan on putting some isolators just to keep the rattling down.
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a million pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" 2012 Jeep JKU "Crush" 1976 Chevy short bed with a 327 and 3 on the tree (Sold it to buy the Blazer) 1971 Chevy Blazer (Sold it) |
If you add isolators, you might want to consider adding same thickness shims to cab and core support. Otherwise, body lines between cab and bed are goin to be off assuming cab/core supports are in good shape, if not going to be even worse.
Thanks Guys!
Any Tips On Installing Everything. Not Sure If Theres A Certain Order. Its a 69 c10 With a Wood Floor. The Bedsides Are Bolted To The Front Header Panel And Rear Main Sill Already Posted via Mobile Device |
I have a 69 with wood floor. When installing floor I eliminated the bolts going through the floor into the cross members for a cleaner look. Will post a pic. Also installed the rubber shims
I don't put the rubber insulators on mine . It's all personal preference as I see it .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
Could be twins .
I had to shim mine a bit to match the bed lines to the cab lines. No rubber insulation for me. I did the same as above and hid the box to frame bolts. No rattles here.
