Straight pipe or cherry bombs. 6cyl
so...
I have a 62 c10. Original 235. Looking to give it a nice sound. I have single exhaust... An looking to give it a little sound. So... Straight pipe. Or Glass pak ? Thanks |
Re: Straight pipe or cherry bombs. 6cyl
Probably depends if you want to risk getting a ticket or not.
Of the 2 choices you listed, I'd go with a glasspack. A long one.
![]() ![]() Join Date: May 2015
I've had straight and cherry bomb...liked neither..sound cool for a little while but gets really annoying in a hurry...I've never heard a magnaflow on a 6 before...but I'd try that if it were mine
But of your 2 choices ,glasspack..
Who Changed This?
![]() Join Date: Jan 2013
The older I get, the more I like the idea of a quiet(er) exhaust. There's already enough road noise and things going around you that more noise is just...noise. I have tinnitus from mechanic work in the engine rooms of Navy ships, drag racing with open headers, etc. All that quiet isn't bringing my hearing back, though. I vote for a stock setup, even though it wasn't offered as an option.
Steeveedee nailed it. I too wish I had thought more about my hearing. For me it was too much gasoline powered noise. My ears ring constantly. Even simple noises like bathroom fans, music, wind, and TV will make the problem flare up and the ringing becomes very loud.
Truth be told a loud exhaust really doesn't make you all that different from the crowd in an era when everybody and their mother has a loud cat back system on their daily driver anyhow. |
Just my opinion but the straight pipes will really get annoying pretty fast and would attract attention from the Police darn near instantly! The glass packs or a cherry Bombs are really not much better, depending on which ones you get.
I know it was not an option but a split exhaust manifold or Fenton headers with the right size pipe like 2" or 2.25" with Flowmaster 40's or 44's do sound Amazing! Snafu1 |
![]() Join Date: Dec 2009
Of your 2 options ,I would pick glasspacks.
But you may get a gift from your neighbors. .
#9 | |
Just trying to get some sound from a single pipe. But that set up seems sweet |
#10 | |
![]() Join Date: Feb 2014
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
I basically did the same thing...I said I wanted it to sound like a v8, but not a d-bag v8! Quieter is better these days for me for sure.
I say if you want it loud with that poppy backfire noise go for it. Just make sure it is all legal.
![]() ![]() ![]() Join Date: Jan 2018
I drove my truck to the exhaust shop after I cut the muffler off. It was fun for that little bit, but my ears did hurt a little after that 20 or so minute drive.
I chose to use a Black Widow Exhaust Venom 250. I don't hear it inside the cab unless I get on the throttle some. I can't speak for how it sounds from outside the truck as I've never had anyone else drive it without me in the cab. I've had many friends tell me that it's loud though. The Venom 250 might not be exactly what you're looking for, but Black Widow makes several other mufflers
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
#15 | |
I have a 235 just looking to get a little sound from. |
#16 |
To the OP: you should certainly get what you want be it loud or not because believe me, I get it. I loved the sound of Porter Steel-Paks as I banged thru the gears..... but now that we have kind of turned this discussion a bit toward quiet and loud, I thought I'd add something else. When I made my truck quiet, I was able to really dial in my distributor curve since I could now hear the motor pinging off the line when I lugged the clutch. (Maybe it was pinging a bit all that time, but I never heard it until I finally went quiet.) I then bought a timing tape for my balancer and really dialed my distributor by taking a couple degrees off the initial and bringing the mechanical in earlier. I would have never thought of doing that with my glasspacks because, well, it was to loud to really hear the actual motor. All I heard was the exhaust. The ponies I gained in the timing curve more than offset any loss caused by the quiet exhaust. Also as a secondary bonus to the new mufflers, I now hear cars coming up on my flank when going down the freeway.
#17 | |
This is something I was taught at a young age ![]() A well tuned engine with Turbo or regular mufflers is (A+) for me ![]() .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build Last edited by Getter-Done; 02-27-2021 at 10:29 PM. Reason: spelling |
#18 |
![]() Join Date: Oct 2006
When I got my truck I had some 15" glass packs installed. I liked how it sounded ,but that was a bout 15 years ago. On longer trips it can get a bit annoying.
![]() Here is a very short vid on how it sounds now . https://youtu.be/IYqtxakIqkE
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " Last edited by slepysal; 02-28-2021 at 01:16 AM. |
#19 | |
i have a 62 an noticed you have a different brake/clutch master set up.. pm me on that as i wanna upgrade out of my original 1 master cylinder |
#20 |
![]() Join Date: Oct 2009
In what state is a straight pipe legal? I think I’d like to live there, but even if I did, I’d still install a muffler.
#21 |
Not a 6 cylinder, but I had a 79 Z28 that I put glass packs on. I dug the sound. A previous job I had Flowmaster as a client. The HR person I dealt with sent me a set of Flowmasters for my Z. I was not thrilled with the sound, but I was young and could say I had them. LOL.
My son just got a do it yourself setup from Summit, I think they had Thrush mufflers? I really like that sound. Low grunt, but not too loud. He is 19, so of course he wants louder. I told him, knowing from experience, loud pipes only attract the cops. I'd give glass packs a run, if you are only buying one it won't cost you too much RR |
#22 | |
im 47 an love the hotrod sound. cops here in Toledo dont really bother us hotrodders or bikers.. unless your acting a fool. im defiantly gonna give the pipe a little sound.. as previous mentioned. the venom 250s sound good too. |
