02-28-2021, 10:55 PM | #1 |
Choke wire?
Can someone tell me if they think this wire would have been for an electric choke for a 292? 71 GMC 4x4. Previous owner had a manual choke with lever under dash. My bezel doesn’t have a spot for manual choke like I’ve seen on others.
Posted via Mobile Device |
03-01-2021, 01:29 AM | #2 |
Re: Choke wire?
Nope, not for the choke.. The choke wire is a single wire with a single connector... Among other things, that connector/wires could be for the alternator....
03-01-2021, 01:22 PM | #3 | |
Re: Choke wire?
Thanks. |
03-01-2021, 04:04 PM | #4 | |
Re: Choke wire?
03-01-2021, 02:01 PM | #5 |
Re: Choke wire?
Could have been a divorced choke as well.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
03-01-2021, 02:08 PM | #6 |
03-01-2021, 02:11 PM | #7 |
Re: Choke wire?
It uses a thermostatic coil mounted on the intake manifold with a rod that runs up to the choke linkage. As the engine warms up, the coil winds up and opens the choke. When the engine cools down, the coil unwinds and closes the choke. It will also have a vacuum pull-off to open the choke slightly after startup to keep the engine from flooding.
03-01-2021, 04:37 PM | #8 |
Re: Choke wire?
This is a divorced choke. As mentioned above, that rod is connected to a spring (that has a technical name LOL) under the silver cover. As it heats up, that spring is what works with the rod to open the choke. No power needed.
03-01-2021, 08:21 PM | #9 |
Re: Choke wire?
03-01-2021, 10:13 PM | #10 |
Re: Choke wire?
nothing compares to a manual choke, they are the best!
03-02-2021, 12:02 AM | #11 |
Re: Choke wire?
03-02-2021, 12:36 AM | #12 |
Re: Choke wire?
In Canada , Without a doubt . Once you get used to using a manual choke to start your truck in colder weather You'll be glad you did .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
03-02-2021, 12:44 AM | #13 |
Re: Choke wire?
Always a manual choke in your area Ryan. When I lived in Alberta I converted all my chokes to manual.
03-02-2021, 01:41 PM | #14 |
Re: Choke wire?
with a manual choke, you get two benefits. the first is simplicity - you pull the wire, the choke flap closes and fast idle is engaged. if it's not working right, it's very easy to diagnose.
second, you get full control. with an automatic choke, it's up to the heat from the engine or resistive element to control the choke. so, for instance, with an electric choke, you might find the choke comes off of fast idle more quickly than you'd like. with a manual choke, you just leave the cable pulled out a bit and push it in fully whenever you are ready. with the electric choke, you have to rotate the choke housing to adjust the internal tension and keep doing that until you get it just right. |
03-02-2021, 08:16 PM | #15 |
Re: Choke wire?
Only problem with a manual choke is when you have a senior moment and forget to push it in all the way after everything heated up. Getting the "Divorced" automatic to work right sometimes takes a year. You get it to pull off nice in the summer then it won't come off when it's cold. They are good when they work right and they suck when they don't.
72 C20 292 3OTT 77 GMC 2500 4x4 Longstepper 350 4sp 50 3100 ex Airforce/Town of Mendon fire truck 72 GMC 1500 2wd short stepside 250 4sp 78 GMC 2500 4x Longstepper 292 4sp 54 6400 Chevy 5 window 4 sp 2sp vac rear end Shell oil truck/dump truck (Norman) |
03-02-2021, 08:20 PM | #16 |
Re: Choke wire?
If I wasn’t using a manual choke I simply had two linkage rods. One for summer, one for winter. Easy to swap out. Made from clothes hanger wire.
03-02-2021, 08:22 PM | #17 |
Re: Choke wire?
I like the way you think!
03-03-2021, 02:02 PM | #18 |
Re: Choke wire?
I've swapped every vehicle back to automatic choke I've ever had that had been converted to manual. With a decent carb and an adjusted choke it has always been the better functioning system. I have a divorced on my 69 one ton now but I rebuilt a carb I had that is a late 70's electric heated choke Q-Jet. I ran it on my daily driver 72 GMC for years without a hiccup. Ran it in -40 to +40 C. Started every day.
Saskatoon, Saskatchewan Canada Last edited by StingRay; 03-03-2021 at 02:09 PM. |
03-03-2021, 02:17 PM | #19 | |
Re: Choke wire?
03-03-2021, 04:58 PM | #20 |
Re: Choke wire?
I live in a climate that goes from -40F to +105F. I never have a problem like that. If it does that it's a problem with carb and/or choke adjustment. I've driven a lot of carbed vehicles in my 40 plus years of driving and all here in this god forsaken climate. None have had a manual choke. If they can work here they can work anywhere. As far as flooding goes. Floor it and a Q-Jet will open the choke butterfly. If it doesn't it's not adjusted correctly.
Saskatoon, Saskatchewan Canada |
