03-13-2021, 04:05 PM | #1 |
12 bolt to a 10 bolt rearend bolt on swap?
Ok. So lil bro has a 87 "r10" 2wd. It has a 12 bolt 2.73 rear end. We put in a 700r4 and its lazy and lugs all to hell. Will a 10 bolt swap from a 12 bolt without any modifications?
Thanks yall. U saved my ass more then once. |
03-13-2021, 04:19 PM | #2 |
Re: 12 bolt to a 10 bolt rearend bolt on swap?
I don't think it is a bolt in swap. You'll probably need to change the spring mounts at least. I personally don't know of any 10 bolts that came in the 87 and older trucks, so I don't know what the width differences are (if any). It might be easier to change the rear gears to a 3.23, 3.42 or 3.73 gear.
03-13-2021, 06:07 PM | #3 |
Yes, direct swap. The 10 AND 12 bolt came in the 73-87 body style.
03-13-2021, 09:54 PM | #4 |
I did not know that. I have never seen a 10 bolt in any of my squares. Learn new stuff all the time.
03-14-2021, 01:47 AM | #5 | |
I have an 86 K5 that came with a 10 bolt rear (military M1009). I swapped the 12 bolt out of my 82 K5 a couple years ago, and it was a bolt in. Somewhere between 82-86 the parking brake cable layout changed, so I had to swap the parking rear brake cables on my 82 12 bolt for the later style. And the yoke on the 12 bolt for some reason took a smaller U joint. But the axle definitely bolts up to the springs. I didnt take a pic of the rear axle coming out, it was too cold... But I promise it did happen.
1988 "Crane Truck" C30 - 350, SM465, with a 15' knuckle crane - thread 1986 M1009 - 6.2 Diesel, SM465, 2 speed aux trans, NP205 - thread 1979 Corvette - 350 T5 1977 Jimmy - 350, TH400, NP203 1982 Blazer - 350, 700R4, NP208 - Totalled, now a parts truck Scratch built 16' flatbed trailer - thread |
03-13-2021, 06:14 PM | #6 | |
what ? ? ? ....... 10 bolt rear was as common on 81-up as 12 bolt on 80-older was for 1/2 tons . basicly direct bolt in IF 2wd to 2wd or 4wd to 4wd . for the lug count and the shock mounts . brakes are the same pattern so if need be pull the shafts . swap brakes . new axle seals and install and run . u-joint size might be different and need trick joint . how did the 87 get the older 12 bolt ?
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
03-14-2021, 07:28 AM | #7 |
my 86 had a 10bolt
03-15-2021, 12:33 AM | #8 |
Why would you go backwards in strength? Do a gear swap and put in a posi at the same time
03-15-2021, 01:07 AM | #9 | |
But I don't know if a 10 bolt is backwards in strength. The 8.5" 10 bolt ring gear is 3/8" smaller in diameter, but the small pinion shaft and outer pinion bearing on the 12 bolt brings the suck. I don't think you're gonna break the ring gear, but losing a pinion on the trail would be a pretty bad time. The only reason I swapped one into my truck is because it already had a selectable locker (ARB) in it.
03-15-2021, 01:39 AM | #10 | |
I put a 10 bolt in place of my 14 bolt. Because money doesn't grow on trees.
