New Member
![]() Join Date: Sep 2013
Inner Tie Rod to Center Link Issue
Hey all- I'm hoping to get a little help with a steering linkage issue on my 67 with ECE 4/6 drop, power steering and disc brake upgrade which includes 63-70 2.5" drop spindles. All new tie rods but I believe I am using my original center link (I started this project in 2014).
The problem I'm having is the inner tie rod is loose in the center link. The bolt runs out of threads before it tightens up and it seems like the bolt is too small for the hole. Everything else seems to fit great. HELP, what am I missing?! BTW - I have done a frame off on this truck and believe it or not this is the first time I have had to ask a question that I could not find the answer already posted on this site. Could not have done it without you all. Bravo! |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Inner Tie Rod to Center Link Issue
Are you sure you don’t have a 71-72 centerlink?
New Member
I am not sure. That is the one piece of this puzzle that I have no record of and I'm fairly sure it's because I used the original centerlink. Of course it could have been changed out by a PO but I can't imagine why. No power steering and drum brakes. Is there a way to tell?
![]() Join Date: Mar 2003
Sounds like you have the original center link with the 71+ tie rod ends. I think that would do it
New Member
Maybe but I have the receipt for the tie rods and the part number indicates they are for a 67. I will see if I can find them both and compare. I was sure someone else had come across this issue. It's a good thing I love this truck of mine so much because she is maddening otherwise.
