Grille assembly
I'm trying to assemble my inner and outer grille for my 69. It's been a while and I guess I should have taken pictures. I will post a picture of what I thought was a grille assembly kit that I bought a while back, hopefully someone can tell me if this is suppose to work.
![]() Join Date: Dec 2013
Re: Grille assembly
https://www.classicparts.com/1969-72...nfo/61%2D953/#
white plastic clip with screw , Push into hole and tighten screw to expand The metal clip is used on gm cars to install windshield/ rear window trim mouldings . ![]() https://www.clipsandfasteners.com/Wi...SABEgI3a_D_BwE
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
![]() Join Date: Nov 2013
Re: Grille assembly
brothers trucks on YouTube has a great video on how to use pliers with a nut taped to push those white clips in.
Re: Grille assembly
#5 | |
Re: Grille assembly
Re: Grille assembly
Do you have any pictures of what your working with ? grille/ clips /screws ?
Re: Grille assembly
Grumpy, On the first page is the screw and clip, here is a picture of my 69 grille, round holes (I have 3 grilles all alike) also a shot to inner grille with square holes. Were all the originals made with round holes and repo's made with square holes?
Re: Grille assembly
Why not just turn the round holes into rectangular holes
Re: Grille assembly
ZIP TIES are your friend ... laughing, not laughing
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
![]() Join Date: Jan 2012
Re: Grille assembly
Good info.
